Again, I apologize. I'm a digital guy and never deal with analogue sources or equipment. In my ignorance I just assumed a Canopus ADVC-300 was another DV camcorder, since I assumed this thread was actually about DV. It seems that it really has nothing to do with DV.Originally Posted by MacHound1
I just want to stress again that digital luminence levels (16-235 vs 0-255) have nothing to do with the 7.5 IRE setup. Yes, in your circumstance you do have to deal with the setup. But you ALSO have to deal with the luminence levels of your source.Originally Posted by gwoiler
DVD players do not take 0-255 luminence sources and output to 16-235. The source only carries luminence information in the 16-235 range to begin with. (some regions actually can use 8-235) That is all that the NTSC, PAL, and Secam standards support. That is all that YCbrC supports. (what DVD uses.) Its a limitation that applies to everything we do and it has nothing to do with setup. All information displayed on any television must have headroom and footroom in the signal according to the CCIR601 standard. Your VHS tapes already have this headroom and footroom. But when you digitize it some codecs will expand this to 0-255. This is so that it looks correct on a pc monitor. This doesn't gain you anything at all. All it does is remap the luminence values so that they correspond to your monitor. When you output to mpg you have to remap them back to where they were, and you have to do this correctly to avoid hard clipping and to avoid overcompression. I outlined the various ways to do this in my first post.
As for how to handle setup, well I think you can see that others in this thread can give you better advice than I.
Results 31 to 32 of 32
Sure. As is often the case, understanding the problem clearly is the crucial step to understanding what the solution is. I think several people didn't quite follow what you were doing. And went down the wrong tract because of that.Originally Posted by MacHound1
Pioneer Elite CLD-99 laserdisc player - black levels?
By echo1434 in forum RestorationReplies: 40Last Post: 15th Oct 2012, 20:39 -
Black Levels in Windows Media Center using Hauppauge HD PVR
By Mitterhouse in forum Capturing and VCRReplies: 0Last Post: 17th Jun 2011, 14:16 -
Correct Black Levels
By MasterOfPuppets in forum Capturing and VCRReplies: 7Last Post: 10th Jul 2010, 16:38 -
Confused about black levels... again.
By binister in forum Newbie / General discussionsReplies: 5Last Post: 16th Dec 2008, 21:43 -
How do I merge 2 AVI to DVD adding saturation +black levels?
By JoeBolden in forum Video ConversionReplies: 2Last Post: 23rd Jul 2008, 13:01
