Converting old VHS tapes to DVD. The first couple of conversions went fine. Started getting "The program is of different video formats" errors on some files. Other files are ok and are part of same tape. Any ideas whats going on. Using the trial version of TMPGnc 1.5.20.62. Thanks.
Something has changed in your capture settings between the two tracks. It can be something simple (like audio frequency) to something like resolution or bitrate.
In TMPG DVD Author from the Source Setup screen. You have tracks (the boxes on the left) and files (which are added to the tracks).
You can have multiple resolutions, audio or bitrates on one DVD, just not on the same track.
Try adding the file that's giving you the error to a track by itself on the same DVD and see what it does.------------------------------------------------
Phillip
www.allaboutduncan.com
"Oh, they have the Internet on computers now."
Thanks for the reply. When I press "add video" I'm shown 4 programs (clips), I select the first program and when I press "next" and I get the error. If I cancel and select program 2 I get the same thing. If I cancel and select program 3 or 4 eveything is ok and continues. As far as tracks, the program was the first and the only thing I tried to put on the track.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
