  1. I just upgraded my desktop box and plopped in a new motherboard, P4-2 CPU and a few extra fans...
    I'm noticing that the CPU temperature for 'normal' operations is averaging 32-34 degrees (89 to 93 F)
    When I tax the system via MPEG encoding, capturing, etc. the temp is jumping up to 40-42 (105 to 108 F)
    Is this normal operating temps?
    TJ
  2. Yes. That's about average for mine too.
    Jan 2004
    Mozambique
    I second that.. your temps don't look like they are anything to worry about
    Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Third opinion, everything is just fine. I have a couple machines with 2.4's and the idle at 31/32, get into the 40's occasionally. All normal.
  5. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    purely from memory, the P4's are good up to 80C, so 42 is nothing to worry about.
  6. I was so concerned about this issue that I gave Intel a hollar...
    They denoted that my particular CPU (P4-2Ghz) is good to 70 C -- "don't worry until you hit mid sixties"
    TJ
