  1. First I apologize if I have posted this topic in the wrong forum, I had to choose between this one and DVD Authoring.
    Second I want to apologize for my English, I am Dutch and speaking English is not so hard, but writing it down correctly is a bit harder, so please be patient with me!
    This is the problem:
    I wanted to create a (PAL) DVD using a .avi with the following audio stream according to VirtualDub:
    Sampling Rate 48000Hz
    Channels 5 (Stereo)
    Compression AC-3 ACM Decompressor
    I demuxed the audio using VirtualDubMode.
    With VirtualDub I changed the .avi framerate to 25 fps.
    This 25 frames.avi I used to create an .m2v file in TMPGEnc Plus.
    I succesfully changed the audio framerate in BeSweet from 23,97 to 25 frames.
    I authored the files in Tmpg Author and burned them with Nero.
    To my surprise there was no sound on my authored DVD when played in the stand-alone APEX DVD-player.
    I checked the .ac3 file in MediaPlayer Classic and it played fine. I used a created .vob in MediaPlayer Classic and that played fine too.
    I am so confused, I have created DVD's with AC3 sound (6 channels) before, no problem there.
    Can anyone please tell me where I went wrong?
    Thanks in advance!
    funlovin
    (not having any fun at all at this moment!)
  2. Did you try to play the authored DVD using WinDVD or PowerDVD using the play from folder option. This allows you to play a dvd from your Hard Drive.
  3. Yes I did, I forgot to mention!
    In PowerDVD also there was no sound!
