Hello,
Got a few audio questions for you all 8)
When i am creating a dixv file to MPEG2 ready for buring to a DVD-R i encode the audio seprate from video, is this the recommend way ?
I encode the video with TMPEG.
I extract the audio from the divx file to .wav format with GoldWave then covert it to AC3 or MP2.
How do i find out what i should encode the .wav toshould i use AC3 or MP2
Also what bitrate should i use
I am using ffmpeggui to encode the audio, is that the recommend program ?
Cheers
Results 1 to 12 of 12
gsvgaming.net sponsored by 4u-servers
AC3 is the most "compatible" compressed Video DVD audio format you can use - not all NTSC players play MP2 audio. LPCM is also an alternative, but since that is uncompressed, taking about 10 times as much valuable space compared to AC3, I'd recommend against it. I use 192 kbps 2 channels stereo AC3 encoding with ffmpeg.
/Mats -
Cheers for that will stick to AC3 8)
gsvgaming.net sponsored by 4u-servers -
You are in UK, so I bet that you have a region 2 / free standalone player.
Those players support mp2 for audio officially.
The problem with the mp2 audio, is a region 1 / NTSC issue only. -
Yep i do live in the UK, however my DVD player can play NTSC and PAL DVD's.
Does MP2 have a better quailty than AC3 ?gsvgaming.net sponsored by 4u-servers -
No, AC3 is better.
BUT: mp2 is easier.
All region 2 DVD standalones play NTSC. The reason is Japan which use NTSC and is region 2. -
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
BUT: mp2 is easier.
In what way?
/Mats -
Would someone give an example of an NTSC DVD player that does not support mp2? I have an ancient Toshiba DVD that plays only DVD and CD.no VCD/SVCD and it supports DVD made with mp2 audio.
If you have the original ac3 track demuxed from the DVD use it. If your converting I would use mp2. There are no good ac3 converters avaliable as freeware or shareware. -
ffmpeg / ffmpeggui has served me well so far for all my wav to AC3 needs, even if I'm aware of some compatibility issue with Pioneer players (I don't have one of those, and never will).There are no good ac3 converters avaliable as freeware or shareware.
/Mats -
MP2 is easier for many reasons:
1 - DVB transmissions are mp2 (AC3 exist only on few channels). So you use this for source as is (no conversion is needed)
2 - Realtime mpeg 2 software solutions use mp2 (PowerVCR, WinDVR, Mainconcept, etc.
3 - You can load any avi to TMPGenc, load a template, hit encode and end up with a ready mpeg 2 with mp2 audio ready to burn to DVD disc.
For AC3 (which is a need only for the Region 1 users) you need to convert your audio source to ac3 and then multiplex it during authoring. Extra steps compared to mp2...
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
MP3 vs AC3
By thezanny in forum AudioReplies: 1Last Post: 9th Mar 2011, 17:50 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
Looking for simple software that will convert mp2 mpa to mp3
By jimdagys in forum AudioReplies: 23Last Post: 20th May 2008, 08:26
