hey , can someone give me a link for this so i dont have to rely on my softwares reencoder. thx!
Mikeman,
I don't know what it is you're asking for. If you want to know how to make a DVD-compatible MPEG using TMPGEnc, there are plenty of guides on the bar to your left under convert. Here's the link to save you a few seconds:
https://www.videohelp.com/guides.php?tools=1&madeby=&formatconversionselect=to+DVD&howt...or+List+Guides
If this isn't what you're after, can you please give some more information so your question can be addressed correctly?
Thanks,
Cobra -
sorry , what i realy wanna do is take a bunch of concerts i have in mpg files and encode them into dvd formatso that when i try to burn 4 hours of them on 1 dvd-r, my burning program (neodvd,ulead moviefactory 3)
wont go thru hours of encoding and then tell me theres not enough space on the disc for what im burning even though the project size said it was under 4.7 gig. im having a hell of a time getting more than 2 hours on a dvd. so if i can have the files i want encoded already, ii can test out these programs easier. thx again -
beleive me ive looked, i never seem to find the right one that tells me how to take any type of mpg/avi to dvd ready format mpg
Mikeman,
The reason you can't fit more on is because you aren't dropping the bitrate. If you drop this then it uses up less data but you sacrifice image quality.
Originally Posted by MIKEMAN
https://www.videohelp.com/convert#4;10 - All formats --> DVD
https://www.videohelp.com/guides.php?guideid=75&howtoselect=4;10#75 - Guide for ANY VIDEO SOURCE --> DVD using TMPGEnc
Remember you have to take the file TMPGEnc outputs and author it, so run it through TMPGEnc DVD Author to produce a DVD image, which is burnable.
Cobra
Really struggling making a high quality MPG from dvd on hard drive
By Yarko1967 in forum DVD RippingReplies: 29Last Post: 15th Apr 2011, 09:39 -
Making movie in Vegas from MPG files
By malexi in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jul 2009, 08:05 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
