  1. Hey, I used to hace win2000 in my pc, i captured very good with my sony trv-33. but now i`m using winXp-pro, and i Tired to captured with ulead(as i always did) but the audio is not right, i mean, i choose 48KHz, but the captured file sin 32 KHz, why??????????????????????????????
    May 2003
    Peterborough, England
    As DV is a simple file transfer, you are getting what you started with. On the menu on your Sony you will find an audio setting for 12 or 16 bit PCM. 12 bit is 32kHz audio, 16 bit is 48 kHz audio. You have probably changed the setting to 12 bit at some time.
  3. you know, i have some old(last year) miniDV cassettes, and i did capture very good with audio 48KHz, very nice Home video DVD (i used to have windows 2000, since 2 weeks i use windows xp pro). I still have them so i tried to capture again...not succesfull, the audio was 32 KHz with the same program ulead.
