how should I set this up?
CD-RW Drive
DVD-rw CD-rw combo drive
2 hard drives
What should be on the primary controller master and slave?
Which device should be master on what controller?
what should be on the secondary controller master and slave?
Put 2 hard drives on the same controller, i.e either primary or secondary controller. Hard drives considered a faster drive compare to optical drives. So, put in this way will not much affect the performance of the drive since the slower drive, i.e optical drives is not on the same controller. (fyi, slower drive such as optical drive operate at 33MHz, whereas harddrives operate at at least 66MHz. If hard drive and optical drive were put on the same controller, the performance will be affected by the slower drive.)
For the optical drives, guess which drive's firmware is likely to be updated then put that drive in master because some firmware updates require the drive to be located on master.
Can't Read DVD+RW with XP
By Ailanthus in forum MediaReplies: 7Last Post: 13th Nov 2010, 05:44 -
DV FAQ - Read me first
By Baldrick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Jan 2008, 17:40 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04 -
MKV2TS.......read in!!
By oldpainlessuk in forum Video ConversionReplies: 8Last Post: 8th Jun 2007, 08:31
