I'm sure there's a simple solution to this problem that I missing somehow. I just created a DVD in DVD Studio Pro 1.5. When I preview it on the computer it navigates through the 6 buttons perfectly. But, when I burn the project to a DVD and play it in my DVD player, there is a short pause between each button that I navigate through. I also noticed that when I navigate from the first button to the 2nd the chapter on the DVD player changes from 0 to 1 and so on, until I get to the 6th button and the chapter reads 5. Does anyone know why this might be happening? I should be able to just go up an down through the buttons without any pauses.
Is this a motion menu, or does the picture at the back change as you move from button to button ? It sounds like you have created a motion menu with a different scene shown depending on what button has focus. This is done by creating a series of clips (or chapters in your instance), one for each button, then auto shifting to the next/previous one based on the button your are moving to. It takes more time for a single speed DVD player to move the correct menu scene/chapter that your soft player playing off a harddrive.
It's a still menu. Is there an easy way in DVD Studio pro to get rid of the chapters I've somehow created?
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 2nd Apr 2012, 23:54 -
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Menu Buttons looking odd
By TerryNG in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 00:28
