I have this HDTV (1280x720) mpg video file of amazing quality that I would like to keep in a DVD. Does it need conversion to author the DVD? Will it maintain its quality in the DVD format or will it be degraded? Thanks.
You must reencode it to dvd standard. The quality will be degraded.
www.videohelp.com/dvd#tech
You have to wait for some hd-dvd standard before you can author hd-dvd... -
Ok, thanks. Sorry for the double post, I was unsure which topic was more relevant.
DVD authoring question...
By mjl1297 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2011, 10:26 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / IPTVReplies: 7Last Post: 30th Sep 2009, 00:13 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 02:40 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2007, 09:00
