I have this HDTV (1280x720) mpg video file of amazing quality that I would like to keep in a DVD. Does it need conversion to author the DVD? Will it maintain its quality in the DVD format or will it be degraded? Thanks.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
the dvd-video standard supports 720x480, 704x480, 352x480, 352x240, 720x576, 704x576, 352x576 and 352x288.
You will need to re-encode your file for it to be dvd compliant - this will lose a fair bit of resolution. you can of course record the file to a dvd-r as normal data, but currently you can only play it back in a PC.
Thanks for the info.
Regarding what you said about the file being played only in a PC, I guess that if I had an HDTV TV monitor I could hook it to my ATI 9800 AIW card (which I think has HDTV output) and diplays the output from the PC in the monitor keeping the same quality, right?
PLEASE don't cross post.
https://www.videohelp.com/forum/viewtopic.php?t=219672&highlight=
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 15:37 -
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 22:12 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / IPTVReplies: 7Last Post: 30th Sep 2009, 01:13 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 18:36 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2007, 10:00
