Hey everyone,
I will be doing some basic capturing with the Plextor PX-M402U. I will not require to edit the captured video in any way.
Do I need the winDVD creator? Or can I just capture with WinDVD player and store the movies on my HD until I want to burn?
I will be capturing clips that are maximum 2 min. in length.
Thanks for your input
WinDVD Player is just that, a player. You can use any dvd creation software you choose, ULead DVD, WinDVD Creator, Sonic's MyDVD and DVDit, etc.
You use Creator2 to capture mpeg2/divx or vcd clips and WinDVD to playback the MPEG2/DIVX files or DVD. Plextor bundles WinDVD 5 with M402U so buyers can also play DVD on PC.Originally Posted by thebiomed
Use Creator2's DVD high quality presets if you just want to capture a few sets of 2 minute clips. Then author the clips and set them as chapters.
Make sure to download and apply the latest driver http://www.plextor.com/eng/support/downloads/M402_1005.exe
They fixed audio sync problem related to VHS capture from M402_1004.exe. As well d/l the patch for Creator2 http://www.plextor.com/eng/support/downloads/2.0B014.339-18595.WCreator2.Plextor.from....1-17826.iU.exe
Recording from Windows Media Player
By PaoloC in forum EditingReplies: 1Last Post: 18th Oct 2008, 09:45 -
Recording video-stream from Ray V player or sopcast
By 1234567 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Sep 2008, 14:47 -
Problem recording from vlc player using camtasia recorder
By method in forum Video Streaming DownloadingReplies: 6Last Post: 27th Mar 2008, 22:07 -
recording media player visuals with music files
By kamots18 in forum AudioReplies: 1Last Post: 15th Jun 2007, 00:56 -
problem recording from windows media player 11 using camtasia
By method in forum Newbie / General discussionsReplies: 0Last Post: 27th May 2007, 16:42
