I am using DVD2SVCD to convert AVIs to SVCD image files. I have done many and had it work great each time, however, I have one AVI file that seems to have an error in it.
Every time DVD2SVCD gets to the part where BeSweet runs, it extracts the audio, then it says "encoding audio" and tries to run the following command:
"C:\Movies\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Movies\DVD2SVCD\Movie\Extracted_audio_1.wa v" -output "C:\Movies\DVD2SVCD\Movie\Encoded_audio_1.mp2" -logfile "C:\Movies\DVD2SVCD\Movie\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 128 -m s )
and promptly crashes. I have no idea how to fix this problem, or even exactly what is wrong. All three of those files it is trying to process exist, so thats not the problem.....
Anyone know what I could try to do to find out what the problem is? I have watched the AVI file it plays just fine. I have also installed the latest version.
One thing you could try is converting your avi's audio to wav. Open the avi with Virtualdub, go to the video menu and select "direct stream copy", go to the audio menu and select "full processsing mode" and then go to file and save as avi with new file name. Try running that through dvd2svcd.
That didnt work *cry*
I used TMPGenc and converted it to an mpeg hoping that would fix any errors, but now I dont know how to convert from an mpeg to SCVD. I do have a program called VCD Easy that appears to be able to do it, but the evaluation doesnt let me work with anything over 200 megs heh.
Anyone know any other program I can try that can do mpeg to SVCD and allows you to specify how many disks to use? (I have been using Tylo for that) -
Hey pepz
I was wondering if anyone sorted this problem yet.
same thing is happening to me and plus their is no other tool that makes svcds with subs at this quality either
Problem with Onlocation crashing - please help!
By goodpractice in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2012, 13:52 -
problem with besweet while changing 25 to 23976 fps
By montevo in forum AudioReplies: 5Last Post: 23rd Jan 2012, 04:39 -
Adobe After Effects 7.0 Pro Crashing Problem!
By SciFiGeek17 in forum EditingReplies: 1Last Post: 3rd Jan 2010, 19:01 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38
