I have noticed that I can change the .vob extension to .mpg and it will play in some applications. However, if you try to import it into a video editing application I usually get the message "...unsupported format". Is there some kind of 'header' or something that needs to be changed? If so, how?
If it works, don't fix it.
Multiplexing is what makes a vob and it's done in the authoring process.
Demultiplexing gets you the elementary streams (MPEG file, Audio, Subtitles).
I know that Vegas Video accepts VOB files. Which program are you trying to use VOBs directly in? -
Vobedit can demultiplex into elementary streams.
Mpeg video wizard and TMPGEnc DVD author can accept VOB's for editting."Art is making something out of nothing and selling it." - Frank Zappa -
Since a Vob file can contain more than one audio stream and subtitles simply changing the extention to .mpg doesn't look like such a good idea. I suppose the standard technique is to DeMultiplex the video stream and your desired audio stream from the vob file, then Multiplex them into a MPEG file. Tmpgenc is my choice of programs for this.
Good luck. -
That explains why the changed files are sometimes in another language. Yes, I could open .vob in VEGAS, but it only loads part of the file (I suppose to the first chapter break).
I was just trying to save a little time.
Thanks.If it works, don't fix it.
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Help please! Want AC3 audio from DVDs but DVD Decrip only makes VOB's
By WBFAir in forum AudioReplies: 6Last Post: 26th Sep 2008, 10:34 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08
