Hi all,
I've realized that sometimes Maestro refuses M2V files, accusing GOP error...
Is there any tool that should fix GOP sequences WITHOUT reencoding the file ?
Thanks,
Zetti
Originally Posted by chas0039
Thanks,
Zetti -
I used to have the latest version of Womble's MPEG-VCR installed on this PC and it had a GOP fixer..
I never used this GOP fixer but you may be want to take a look.
http://www.womble.com/vcr-text.htm
Martin. -
Originally Posted by zedolfblack
It lets me do the 1st and 2nd options, but these aren't enough to DVD standard (that should be 3rd option....)
Zetti
Inconsistent Levels result with filter
By cornfluke in forum EditingReplies: 5Last Post: 17th Dec 2010, 07:24 -
Problem with MKV to DV - Inconsistent Quality?
By aboutblue in forum MacReplies: 2Last Post: 19th Apr 2009, 13:54 -
Fix D2V tool??
By BIFFtheSTIFF in forum Video ConversionReplies: 1Last Post: 15th Jan 2009, 01:40 -
Tool to fix audio pitch problem from DVD?
By haymes in forum EditingReplies: 0Last Post: 29th Nov 2007, 17:15 -
New Tool SetMismatchSUB : Fix , Mix , Edit , Join .SUB file(s)
By Goldenaxe4000 in forum SubtitleReplies: 0Last Post: 1st Aug 2007, 12:05
