  1. Need to know where you can find info on creating MDS files.
    NOWHERE ON THIS SITE DOES IT EXPLAIN HOW TO BACKUP STORE BOUGHT PC GAMES!!!
    Jan 2004
    PAL Region
    Alcohol 120%
    Would you mind mentioning which URL you accessed this site through?
    Please post off topic in our off topic forum.
  4. Appologies, this will never happen again
  5. Originally Posted by burncycle
    Look at the top left of your screen - it reads "VideoHelp" for a good reason! Also, just so you can avoid getting other users annoyed, subject titles like "Help" or "Need advice" don't get very good answers and also are skipped by most users. It also makes searching the forums hard to do, as you will no doubt see when you try in the future. Also, CAPITALS are considered shouting! Rant over, time for some help!
    Now, go to the top of the screen and run a search on "mds" on "All Forums". You should get 76 hits, and they should answer your question pretty quickly. Never underestimate the power of forum searches.
    Here's a few links to get you started:
    https://www.videohelp.com/forum/viewtopic.php?t=219524&highlight=mds
    https://www.videohelp.com/forum/viewtopic.php?t=218269&highlight=mds
    https://www.videohelp.com/forum/viewtopic.php?t=201575&highlight=mds
    It looks like .mds files aren't well known on these boards - you'd be better searching elsewhere. From what I can see, Josef K is right - Alcohol 120% is your best bet.
    Jan 2004
    PAL Region
    Yep, Media Descriptor File.
  7. I'm mainly a video person but, problem has arised that called to have an .mds file created: Alcohol 120%'s website everyone has written on how to mount a mds file but, I need to create one from scratch. funny - you would think by now that someone would have
    Jan 2004
    PAL Region
    This guide assumes you have Alcohol installed:
    1. Put CD/DVD in drive
    2. Start Alcohol, click Image Making Wizard
    3. Follow steps
    4. Say 'Hi' to new .MDS file
    Pretty much the only software that produces this type of file is Alcohol. What are you trying to make an image from? A disc, other image type or files on your drive?
