I have searched the net all over trying to find the DVD covers listed below (Region 1) but with no luck at all. Could anyone help me find these covers or if you may have any could you possibly send them to me, I would really, really appreciate it. Thank you so much for taking time to try and help me and have a great evening.
Taps
Cobb
Nobody's Fool
Dirty Dancing Ultimate Edition
A Soldier's Story
Last Light
Miles Davis Live in Montreal
Tommy James Live at the Bitter End
Christmas Angel Mannheim Steamroller
Christmas Live Mannheim Steamroller
Results 1 to 9 of 9
Thank You,
GolfNut -
jnr thank you for the reply, I only found 2 of the covers here though. Any other suggestions, I have also used the mega search engine for dvd covers without success also. Thanks again for trying to help.
Thank You,
GolfNut -
lgh529, thanks much for the site and tip, I will give this a try.
Thank You,
GolfNut -
if the above sites down't have your title, dvdempire.com has good quailty front and back covers. if you download both and preview in xp and then print from there (photo printing wizard) with "5x7 cut out prints" you get a near perfect cover with about 10 seconds labor. you will have to write in the title on the spine.
aero thank you for the reply and advice. I tried saving the front of one cover, then opened it in XP but the size was too big when printed. Could you tell me how I resize it properly to make it fit using XP, I did click as I always do on "dvd single keepcase" in XP before I printed but the front cover was stretched when printed to the size of a complete front and back cover. Thank you for your help.
Thank You,
GolfNut -
ok, here is what i do.
save the front and back covers to a directory (i keep the urls to http://www.cdcovers.cc/ and http://www.dvdempire.com in a directory called "coverart."
for dvdempire artwork I open the directory and right-click the back cover and select "preview." from that preview i then go to the bottom and hit the icon for print. "this should give you the photo printing wizard." hit "next" and make sure the back cover has a check mark and also check the front cover for that dvd. hit next, ajust your print quaility if you like, hit next again and go about 5 down and slect "5x7 cut out prints. then print. this gives me near prefect sized with a blank spot in the middle for spine to write the title.
notes
a)selecting the back first gives your correct orientation
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 05:20 -
dvd cover desing
By ht0160 in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2010, 16:54 -
How do I print out a DVD cover?
By orfajackson in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 15:33 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30 -
where to find DVD cover ?
By ktnwin in forum MediaReplies: 6Last Post: 11th May 2007, 17:28
