May 2, 2004 - ffmpegX 0.0.9g
http://homepage.mac.com/major4
What's new:
- All DVD presets, including DVD hi-bitrate and DVD lo-bitrate now support AC3 5.1 sound encoding.
- "Decode with Quicktime" option now also decodes MPG audio tracks.
- mp2 encoding for VCD/SVCD/DVD presets is now super-fast.
- Improved "fast SVCD" encoding.
- Added manual "letterbox" settings for ffmpeg engine (Filters tab), enabling addition of black padding areas at Top/Bottom/Left/Right (values in pixels). To correctly use this feature, you should first reduce the image size depending on the source aspect ratio, then add black areas to match to playback aspect ratio. (Note: When "Decode with Quicktime" is used, auto-letterboxing is always enabled and will overrid the manual settings.
- Updated to ffmpeg CVS of Apr 30, 2004.
Results 1 to 9 of 9
Hope i'm gonna received my activation key soon...
Here what i get when i try to mail to your box:
Your message cannot be delivered to the following recipients:
Recipient address: major4@ims-ms-daemon
Original address: major4@mac.com
Reason: Over quota
Originally Posted by major
i take a pal-dvd which is 16/9 anamorphic (1:2.35), i use the fastSVCD preset, change the video size to 16/9 (480x272 px.) than, to arrive at a 4/3 ratio, i add 44 px. of black padding on top and bottom?
thanks a lot!
another thing i have noted is that fastSVCD in its standard configuration is incompatible with my standalone DVD player. demuxing, muxing as xsvcd and authoring as xsvcd with MMT solves the stuttering video issue. i haven't tried yet doing the xsvcd step in ffmpegX...
a last thing: the mpeg2-video produced by ffmpeg is -imho- simply fantastic, thanks for including this in your app!
ffmpegX 0.0.9y-L for Mac OSX 10.7 "Lion" released
By major in forum ffmpegX general discussionReplies: 10Last Post: 29th Jan 2012, 03:27 -
Avast 5 Released...
By Poppa_Meth in forum ComputerReplies: 11Last Post: 29th Jan 2010, 14:48 -
AV Linux 3.0 released.
By GMaq in forum LinuxReplies: 9Last Post: 14th Dec 2009, 08:38 -
ffmpegX 0.0.9y released
By major in forum ffmpegX general discussionReplies: 12Last Post: 28th Nov 2008, 01:39 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10
