Results 1 to 13 of 13
  1. I have problem with burn dvd from or copy anything from HD
    I alway have scsi command abort
    how to fit. please help
    here is message
    MD3000
    HOME
    1A23-0036-8030-1289-0348-9217
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
    Nero version: 6.3.1.6
    Recorder: <TDK DVDRW0404N> Version: 1.0A - HA 2 TA 0 - 6.3.1.6
    Adapter driver: <> HA 2
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <JLMS XJ-HD166S >Version: DS18 - HA 2 TA 1 - 6.3.1.6
    === Scsi-Device-Map ===
    DiskPeripheral : WDC WD800JB-00CRA1 17.0 nvidesm Port 1 ID 0 DMA: Off
    DiskPeripheral : MAXTOR 6L080J4 A93. nvidesm Port 1 ID 1 DMA: Off
    CdRomPeripheral : JLMS XJ-HD166S DS18 nvidesm Port 1 ID 0 DMA: Off
    CdRomPeripheral : TDK DVDRW0404N 1.0A nvidesm Port 1 ID 1 DMA: Off
    === CDRom-Device-Map ===
    TDK DVDRW0404N G: CDRom1
    JLMS XJ-HD166S F: CDRom0
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 1023MB (1048048kB)
    Free physical memory: 694MB (711576kB)
    Memory in use : 32 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    28.4.2004
    UDF/ISO compilation
    9:41:04 PM #1 Phase 112 File dlgbrnst.cpp, Line 1841
    DVD-Video files reallocation started
    9:41:04 PM #2 Phase 114 File dlgbrnst.cpp, Line 1841
    DVD-Video files reallocation completed (no file modified)
    9:41:04 PM #3 Text 0 File Isodoc.cpp, Line 6062
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 2 (Max. of 31 chars)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    9:41:04 PM #4 Phase 111 File dlgbrnst.cpp, Line 1841
    DVD-Video files sorted
    9:41:04 PM #5 Text 0 File Reader.cpp, Line 118
    Reader running
    9:41:04 PM #6 Text 0 File Writer.cpp, Line 124
    Writer TDK DVDRW0404N running
    9:41:04 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3898
    First writeable address = 0 (0x00000000)
    9:41:04 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3898
    9:41:04 PM #9 Text 0 File Burncd.cpp, Line 3198
    Turn on Disc-at-once, using DVD media
    9:41:04 PM #10 Text 0 File DlgWaitCD.cpp, Line 244
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2133455 (474:06.05, 4166MB)
    9:41:04 PM #11 Text 0 File DlgWaitCD.cpp, Line 249
    Write in overburning mode: FALSE
    9:41:04 PM #12 Text 0 File DlgWaitCD.cpp, Line 2107
    Recorder: TDK DVDRW0404N, Media type: DVD-R
    Disc Manufacturer: Yi Jha - n 001
    Disc Application Code: 64, Disc Physical Code: 193
    9:41:04 PM #13 Text 0 File DlgWaitCD.cpp, Line 410
    >>> Protocol of DlgWaitCD activities: <<<
    9:41:04 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2133456 (2133456) = #2133456/474:6.6
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2133456 blocks [TDK DVDRW0404N ]
    9:41:04 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 982
    Prepare recorder [TDK DVDRW0404N ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4369317888, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2133456 | lead-out | 1 | 0x00 | 0x41
    9:41:04 PM #16 Phase 24 File dlgbrnst.cpp, Line 1841
    Caching of files started
    9:41:04 PM #17 Text 0 File Burncd.cpp, Line 4214
    Cache writing successful.
    9:41:04 PM #18 Phase 25 File dlgbrnst.cpp, Line 1841
    Caching of files completed
    9:41:04 PM #19 Phase 36 File dlgbrnst.cpp, Line 1841
    Burn process started at 4x (5,520 KB/s)
    9:41:04 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2342
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    9:41:04 PM #21 Text 0 File dlgbrnst.cpp, Line 1699
    Set remaining time: 13:15,163 (795163ms) -> OK
    9:41:04 PM #22 Text 0 File DVDR.cpp, Line 1619
    Recording mode: Sequential Recording Mode
    9:41:04 PM #23 Text 0 File Mmc.cpp, Line 19864
    Set BUFE: supported -> ON
    9:41:04 PM #24 Text 0 File DVDR.cpp, Line 1760
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    9:41:04 PM #25 Text 0 File Cdrdrv.cpp, Line 8002
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 2FE10 h
    Start sector number of the next Border-In: 2FFA0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
    9:41:14 PM #26 SCSI -500 File Cdrdrv.cpp, Line 1437
    SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x04B00000
    Status: 0x02 (0x03, SCSI_ABORTED)
    HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
    TA-Status 0x00 (0x00, OK)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x26
    Sense Qual: 0x02
    CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
    0x00 0x00 0x00 0x00 0x26 0x02
    9:41:14 PM #27 CDR -500 File Writer.cpp, Line 304
    SCSI command aborted
    TDK DVDRW0404N\H2 T0
    9:41:14 PM #28 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    9:41:14 PM #29 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    9:41:18 PM #30 Text 0 File DVDR.cpp, Line 1970
    EndDAO: Last written address was -1
    9:41:47 PM #31 Text 0 File dlgbrnst.cpp, Line 1699
    Set remaining time: 0:00,000 (0ms) -> OK
    9:41:47 PM #32 Text 0 File dlgbrnst.cpp, Line 1699
    9:41:47 PM #33 Phase 38 File dlgbrnst.cpp, Line 1841
    Burn process failed at 4x (5,520 KB/s)
    Existing drivers:
    File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 2:02:00 AM (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    thanks for you help
  2. I can only guess what the problem is but i may be able to narrow it down.
    This is the third post i've seen in two weeks that has a problem burning with Nero installed and PXHELP20.SYS (Prassi/Veritas driver for win 2K)
    I remember someone suggesting that you turn off the Windows CD burning support but i don't remember the result.
    Jan 2004
    PAL Region
    I've just been replying to a post in which I related to the inbuilt burning engine in XP today. As I say in that thread, I had a lot of problems with XP when I first installed it and tried burning CDs. It may be worth checking to see if XP isn't trying to be the 'do-everything' OS, just so this possibility can be eliminated.
  4. Well then you will have to tell him which service to shut off because i'm on Win2k.
    I know the process starts with "services.msc", but there is no such service in Win2k. (Thank God!)
    Jan 2004
    PAL Region
    CD/DVD burning in XP is not enabled/disabled through services but through right-clicking on each write-capable drive's property sheet. There is the IMAPI service but that appears to be fine with burning apps I use.
    Jan 2004
    PAL Region
    Yes and no. My IMAPI service is set to manual and it runs when I access some form of burning software's capabilities that will start it. Even if I run Nero to check what medium is in a drive. I do, however, have the inbuilt burning switched off for both my writers.
    The service has not made any difference to my CD/ DVD burning successes, or lack of. In fact the only coasters I've had (ever) were due to my old Yamaha taking a hissy fit (when SCSI devices go bad... ) and more recently with a buggy version of Nero.
    So I wouldn't recommend that you must disable or set to manual the IMAPI service - just disable the burning from the drive property sheet.
  7. Bad Yamaha SCSI drive? That can't be too common! Both of mine are still working great.
    Well i'll stick with Win2k, and lyvandu will just have to experiment.
    Jan 2004
    PAL Region
    Well I am talking about a drive I bought in September '99 that I pretty much must have worn out judging by the stacks of CDs I don't have room for anymore.
    It wrote at blistering speeds up to 6x I'll have you know. Ah, those were the days...
  9. Well there ya go, my oldest is 8x.
  10. SCSI command abort is an issue that affects those that meet the following criteria:
    1. You use Windows XP
    2. Your burner is external
    3. Your connection is USB 2.0
    Solution? Hook up your burner to USB 1.1
    It is rumored that Microsoft will have fixed this with the upcoming release of SP2.
    Dan~~
  11. thank for your helps
