hey all, i just ordered my NEC 2500a , but i dunno wich DVD-R i should get... can someone reccomend me some... and should i buy them in 10-25-50 packs?
any suggestions are welcome
thx in advance
Bongo
Results 1 to 9 of 9
save you money and trouble by buying more expensive media. NEC burners are awfully picky about media. Verbatim media and media with Tayio Yuden daye are good.
Also, DVD+r seems better than dvd-r. -
i want media that i can play in most DVD players
cuz mainly iam getting this burner is for dvd movies -
http://www.herrie.org/
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&forumid=86
This one is a NEC forum.
Check the above sites for information on NEC 2550 drives. -
Here is a complete review of the 2500A. Scrool down to the bottom of the page for the actual review. You'll notice that it out performed even the significately higher priced models. It burned to even the cheapest brands with no problem. I use the Data Life DVD-R to get 8X performance. I found some for about 65 cents per disk.
http://www.cdfreaks.com/article/134/1
Media
http://www.radcamdvd.com/page/RDVD/PROD/DVD_MR_4X/VER94613 -
Download Herrie Beta 7. bit set to DVD-ROM. Get Memorex, TDK, or Fuji 4x + and it will burn at 8x. DVDr + set to DVD-ROM = Maximum compatibility. Some Prodisc 4x + (@8x) burns well too.
Good purchase Bongo2, this writer is fantastic. I've tried various media, but I seriously like Memorex DVD-R made by CMC. You can burn them right to the edge all day long and every disc works. They are cheap too, I picked up 100 at Office Depot for $69 on sale.
I haven't had a problem with players refusing to play any either, but some players just won't play DVD-R's, so you may want to check out Herrie's firmware. I have not tried the bitsetting yet myself, but I've heard good things about it and bitsetting your discs to DVD-ROM will guarantee that any player, even the PS2, will play your DVDs. -
damm that media is too expensive.... can you tell me a good one but cheaper? i wanna buy a 25pack maybe 50
but dont wanna spend like 80bbucks
can someone help?
if you want the MOST compatible disc....this is the wayOriginally Posted by Vanderlow
just go on-line, at officedepot.com, or staples.com, or officemax...every week some good media is on sale, like 1disc/1$.....
i like office depot, you can get Maxells dvd+r for 1 buck each..but you have to be pacient.....
personally, I use Sony and Maxell, never had any problem, and at 1buck each...don't bother for something cheap, it's worth it...
Any advice on which media player to buy?
By pomme4moi in forum Newbie / General discussionsReplies: 1Last Post: 11th Oct 2010, 16:08 -
Would you still buy an NEC ND-3520A today?
By Number Six in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Mar 2008, 09:24 -
Where to buy dvd-r media in Europe?
By paragon9 in forum MediaReplies: 3Last Post: 15th Oct 2007, 09:38 -
Imation not working in Nec 2500a
By anubis13 in forum MediaReplies: 3Last Post: 8th Oct 2007, 13:14 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 15:19
