I have some episodes of Friends and Smallville captured from HDTV that I want to convert to dvd mpeg using TMPGEnc. I have used this program without a hitch before and so I was surprised to find that the resulting mpg file lacked the sound. According to Gpsot the episodes have the following values:
Xvid, fps 23.97 and the sound is 055(mp3) and the Smallville epiodes have 123 kb/s (61/ch, stereo) VBR LAME3.93 while the Friends episodes have 142 kb/s (71/ch, stereo) VBR. I am trying to convert to PAL DVD. Any ideas? According to Gspot I have 2 compatible codecs for both audio and video.
Kal
Could be a VBR problem, but from what i read here that should cause audio desync only. I think i would try to extract the audio with virtualdub, using full processing mode, then use that wavefile as input to tmpgenc when encoding. Or, i wouldnt use tmpgenc at all actually, but you like to use it i think so ok
Try the extracted Wav file in mediaplayer or somthing after extracting it.
no sound on some movies when playing with ps3 and mpeg2 codec issue
By dhyane in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 10:18 -
Out Of Sync sound in mpeg2
By JN in forum Video ConversionReplies: 2Last Post: 20th Nov 2009, 04:52 -
Sound delay issue after MPEG2 editing (avidemux)
By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 06:55 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 09:44 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21
