Hello, My name is RJay & I just built a PC. Works great, running on a AMD Athlon 2800 & I have a 512k. anyways, I bought a Dominator DVD Burner / 8x4x12x DVD±RW / 32x16x40x CD-RW / Nero Express. Now The software it came with was for only making DVDs & burning & making copies of DVDs. The problem I have is that it didnt ocme with a DVD Decoder! So I was wodering where can I get a Decoder?! If you can help, Thank you very much.
You are looking for a player.
Try under tools for player.
I recommend media player classic or videolan
both free. You did not say was OS you are using.
https://www.videohelp.com/play -
Or a DVD ripping program like DVDdecrypter or Smartripper. All programs are found in the Tools section, link over there <-<-<-.
"Art is making something out of nothing and selling it." - Frank Zappa -
Or maybe you want the codec to PLAY dvd movies?
try cyberlink dvd codec, you can get it free with the k-lite codec packs....k422
DVD Decoder Choice
By Parc in forum Software PlayingReplies: 8Last Post: 12th Sep 2008, 02:01 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
Problem with DVD Decoder
By alekdaone in forum Software PlayingReplies: 4Last Post: 18th Jun 2008, 14:47 -
suggestions on dvd decoder?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2007, 08:38 -
what's a DVD decoder?
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2007, 17:59
