    Nov 2002
    Los Angeles, CA
    Hi,
    I was wondering if it would be possible to have many different iMovie projects all go into one iDVD project? I have the newest versions of these two programs on OS10.3.
    Thanks,
    Wolfwood87
  2. I think you can drag and drop multiple iMovies into an iDVD menu.
  3. You definitely can. Use IDVD, it is the easiest program for this (or DVDSP if you have it) Just drag the file (as said above) into a button, and it will begin your movie (if you are going over 1 hr, you should have background encoding on to save you time, if not, leave it on best quality and it will encode at the end to get a bigger video file (bigger = better quality - HOpe that helps (it will definitely work) Peace
