System Specs:
P4P800 Deluxe motherboard
Intel P4 2.4GHz 800FSB Processor
Corsair XMS Extreme 2x512MB DDR400 2-3-2-6 Dual Channel RAM
GF FX5900 Ultra 256MB DDR Video Card
Hercules Fortissimo 7.1 Sound Card
Quad Seagate Barracuda 120GB 7200RPM in RAID 0+1
Windows XP Professional with SP1
Sony DCR-HC85 MiniDV Camcorder
All of the latest BIOS, drivers and updates for every device installed.
Can't capture DV in any way, shape or form through the onboard firewire without dropping frames or artifacts in video.
No problem if I disable it and add a Adaptec Fireconnect 4300 card.
Any suggestions????
It looks like you've done everything you can with your onboard Firewire. Unless you can find some info on some forum specific to your MB, it seems like the easiest thing would be to go with a PCI Firewire card.
It's on sale at compusa for $19.99 after all the rebates.No problem if I disable it and add a Adaptec Fireconnect 4300 card.
http://www.compusa.com/products/product_info.asp?product_code=280901&pfp=BROWSE -
Please let me know if this works for you...see my system above....
I have the adaptec pci card...and a 200 gb raid....and it is NOT working.........
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27 -
Problems using a Panasonic DV camera (NV-DS50) in my firewire
By Duck_Plumber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Apr 2010, 10:10 -
Capturing HDTV with a Firewire and Capdvhs problems
By superdud1400 in forum DVB / IPTVReplies: 2Last Post: 31st Aug 2008, 03:15 -
winfast PVR3000 Deluxe Remote Control problems
By teejayh in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 15:10 -
Problems transfering audio in LP mode via FireWire
By aguinsburg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 26th Oct 2007, 17:55
