ripped a dvd movie only with dvdshrink, and went to re author, when opening the title, got this GOP error, does this mean dvdshrink ripped the movie out of dvd-video specifications, or have i got a prob with the authoring programme..?
TIA
DVD Shrink is a transcoder so I doubt it changes the GOP size. Just in case, rip with another tool (say DVD Decrypter) and test to see if TDA gives you the same result. Probably will. If so, you either have an out-of-spec DVD or TDA is talking rubbish. Open the video with an mpeg parser (DVD-Lab has one, Bitrate Viewer too) and see for yourself. If it's true, you'll need to re-encode to fix this. Or you can ignore it and hope it plays fine on your player.
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 10:58 -
Adding Subtitles to Divx with TMPGEncDVD Author 3
By sunthenovice in forum SubtitleReplies: 3Last Post: 13th Feb 2008, 16:24 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 19:08
