Hi, I,ve been editing some movie footage using Windows Moviemaker 2 and my last project ended up at 53 minutes long and 10.3 GB in size.
I,ve also been told that moviemaker does not make files that can be burned directly to a DVD.
My questions are:-
How do I convert them into files that will go onto a DVD and how do I make the file small enough?
Many thanks in advance.
Jazmine
Use TMPGEnc to convert it to an MPEG-2 file that will fit on your DVD. There are a lot of useful guides on the bar to your left - they can help you through the process.
https://www.videohelp.com/convert#4;10
These should help you get started/familiar with TMPGEnc. You should be able to feed in your file no problems and TMPGEnc can convert it.
Good luck,
Cobra
Need a DVD 30 minutes after the game?
By Telemov in forum Newbie / General discussionsReplies: 56Last Post: 15th Feb 2012, 21:39 -
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 16:32 -
How many minutes per DVD without quality loss?
By cinclodes in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2010, 11:57 -
20 minutes to burn a DVD!
By persephone in forum DVD & Blu-ray WritersReplies: 22Last Post: 9th Dec 2010, 14:12 -
latest few minutes missing on DVD
By coxy in forum Newbie / General discussionsReplies: 8Last Post: 5th Jul 2007, 02:47
