I am interested in converting VHS tapes to SVCD or DVD.I have purchased the Dazzle DVCII, but had to return it due to a conflict with my Athlon 1.2ghz system. I tried the WIN TV PVR, and it worked OK, but I had to use a software encoder to convert the mpeg2 to an SVCD format ( and this is slow). My question is: what capture cards will capture, hardware encode to mpeg2 in SVCD format so I can burn to CD or DVD without further rendering ??
"but I had to use a software encoder to convert the mpeg2 to an SVCD format ( and this is slow)"
You dont need to that if you capture to standard svcd settings...the only thing you might have to do is to multiplex the mpeg with svcd settings, it take some minutes. -
Yes Baldrick is rigth if like that to do this e-mail me and I sned you my web page on how to do this or have a bit long intell I get back on line sorry.
shs@advertisnet.com
<font size=-1>[ This Message was edited by: SHS on 2001-11-08 14:31:15 ]</font>
Hardware issues in encoding
By videobread in forum ComputerReplies: 3Last Post: 23rd Nov 2011, 09:38 -
HDMI/DVI to PC hardware card
By ima2hd in forum DVB / IPTVReplies: 24Last Post: 13th Apr 2010, 10:20 -
Hardware Encoding
By jeby1980 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2010, 23:03 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 13:39 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
