I converted an avi into a half D1 mpeg and attemped to burn it.
The mpeg is about 1.2 Gb in size.
Nero says that it's creating transcoding streams and that the estimated time until finished is 1h 40 min. Now, I've upgraded from a PIII 866 Mhz with 512 Mb ram to a P4 2.6 Ghz with the same amount of memory. Back then it was the same estimated time so it doesn't seem to matter whatever CPU you got and I find that strange indeed.
But what's worse is that i get an error message when about 75% is finished. This has happened to several files while others can be burned/authored with no problems, and yes they should all be DVD comliant mpegs as far as I can tell.
Anyone else having these problems?
Results 1 to 1 of 1
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 00:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 01:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 23:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 11:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 08:00
