I recently purchased the Adaptec AVC-2210 converter box and am attempting to use the MyDVD software that it came with. I've tried making a few test DVD's from video captured from a vhs tape. When finished, the menu displays all the different clips that I have captured and I am able to access them by clicking on each individual scene. But I am perplexed by the fact that I cannot skip to the next clip while I am watching the dvd. If I want to watch the next clip, I either have to fast forward through the first clip or go back to the menu and click on the next scene. But I cannot get to the next clip by pressing "skip" on my remote. How can I get author the dvd so that there are chapter breaks between each clip. I believe I am using MyDVD version 4 and would greatly appreciate any help that can be offered.
Although I solved my own problem, I'll post this just in case anyone else has the same problem. I upgraded to version 5 of MyDVD and it has many more options for chapter editing than version 4. With the newer version I was easily able to create chapter breaks between scenes so that I can skip ahead from scene to scene using my remote control.
best thing for that software is to store it in file 13.....
How Big A Boy Are Ya?
Roxio MyDVD menu display
By moviegeek71 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2008, 21:03 -
Why cant i change audio output in MyDVD 10
By LiBiDoXP in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2008, 01:16 -
MPEG audio using MYDVD EMC 9 problem?
By moviewatcher in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 18:54 -
Problems with Roxio MyDVD Basic v9 and other questions
By ForgetSun in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 02:29 -
Limited background Audio in MyDVD 9
By cmblocker95 in forum Authoring (DVD)Replies: 0Last Post: 6th Jun 2007, 15:21
