I have a program that I built on my computer with Windows movie maker and I want to show it on my big screen tv for a party...how can I do this ...My computer has a CD burner but not a DVD burner...Or could I just get a video card with a S-video card...please help.
the video card with s-video out is probably the easiest and less aggravating way to go. sometimes working with video can make you want to tear your hair out.
If you're willing to go out and buy a new video card you might as well buy a DVD burner instead.
Depending on the length, you can convert to SVCD. That also depends on if your DVD player can play SVCD (most newer ones can).
that depends on your budget teegee, you could buy a decent videocard with tv out for about 40 dollars. That is cheaper than a dvd burner.
supreme, not that it matters, but I liked your other avatar instead
Gitreel, not that it matters, but I like your signature quote when interpreted on a "dirtier" level.
thank you. I also have a keychain that says divers do it deeper.
