Hello,
I captured with a HW MPEG2 Decoder the following:
VIDEO: MPEG-2, 720x576 pixels, 25fps, 6000kb/s
AUDIO: MPEG-1 Layer 2, 44100Hz, 192kb/s
How could I convert this file to make a VCD with
the following Parameter, which I guess are the Standard
VCD Parameter.
VIDEO: MPEG-1, 352x288 pixels, 25fps, 1150kb/s
AUDIO: MPEG-1 Layer 2, 224kb/s
Many thanks in advance
Greetings Joachim
you can either follow this http://www.vcdhelp.com/mpeg2tovcd.htm
or get a mpeg2 reader codec so you can open mpeg2 directly in tmpgenc....I think it will work if you install latest powerdvd. -
i have powerdvd 4.0. what i dont understand, why powerdvd could help me to convert MPEG2 Video Stream to MPEG1 Video stream.
is in powerdvd 4.0 a SW MPEG2 decoder implemented, or does powerdvd stores a codec in my W2K ? any name of this codec, so i could look to my installed video codecs ?
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45
