I have an ASF file that I converted to an AVI file using ASF tools. AVI file plays fine on Windows media. I tried converting this AVI to MPEG2 via both TMPGEnc. and MegaPEG with audio problems. When playing the MPEG2 file for MegaPEG, there is no audio component to it but the conversion completed. The TMPGEnc conversion aborted due to an audio erros decoding. Any help would be appreciated. I am running an AMD 1200mhz with 70GB drive with 384 SDRAM.
I had the same problem.
When u have the ready avi file - use Vdub to extract the audio : Under audio menu - choose full processing.
then save wav under file menu.
In TMPEG - use the avi as video source - and the extracted wav as audio source.... The TMPEG does the rest - no aborting
Hope this helps
More audio sync problems (MPEG2)
By mahonni in forum AudioReplies: 41Last Post: 15th Jan 2012, 16:08 -
Problems with converting avi to mpeg2 with HC enconder...
By sgbd in forum Video ConversionReplies: 2Last Post: 29th Nov 2010, 05:07 -
Apple Mpeg2 playback component
By macuser1960 in forum MacReplies: 13Last Post: 5th Mar 2009, 19:10 -
Apple Quicktime Mpeg2 playback Component
By macuser1960 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Mar 2009, 12:33 -
DV AVI to MPEG2 Problems
By neo265 in forum Video ConversionReplies: 17Last Post: 26th Oct 2007, 03:33
