Well... I've never had any problems with IFOEdit (except for the authoring part) and besides, I don't think I can use Ifoupdate the way described in your guide because the ifo files created by maestro are for the movie only, and not for all the PGC's like the original ones. I could use IFOupdate if I knew of a way to rip video and audio from an entire tileset without creating a weird delay. And yes... I know that IFOupdate has an option to create multiPGC chapter files... pretty handy. I hope you find some solution.Originally Posted by TheMatrixx
By the way... thanks for putting so much effort into helping people... You're pretty cool.
Results 211 to 240 of 654
I experience, therefore you are.
Well, TheMatrixx
stop hurting yer brain, I finally did it. I figured out how to fix a multiPGC movie with new subs... Anybody wanna know how? Let yerself be heard!I experience, therefore you are. -
Hej Again The Matrix
Now I Finaly Get The Right Version DVDmastro
And I Tryed Your New Guide, And It Seems To Work Great nd I also Seems To Be Easy To Use, I Have Just One Or Maybe Two Errors/Quistions
When Im Lokking At The Length Of The Movie And The Length Of The Audio I Had Demuxed They Didn't Have The Same Length The Movie Is 1.40.29 And The Audio Is 1.41.10 ?? When I'm Testing My Finaly Result THe Audio Didn*t Match To The Movie, And THe Subtiteles Did not Either Match Even The Movie Or Audio
Now I'm Asking What Do I Wrong ?? Please Help Me
Best Regards
Flarup -
Now I Finaly get the picture and subtitle matching, but the audio is still out of sync, what do I wrong ??
Best Regards
Flarup -
Hi Flarup. try demuxing the audio directly from the DVD with VobEdit. (Demux All Audio Streams). Let me know if it works. Post a screenshot of the Maestro after you have loaded the *.m2v file and the *.ac3 files, i wanna see the timings. IF THE DVD HAS MORE AUDIO FILES PUT THEM ALL TO SEE THE TIMINGS.
Follow the white rabbit -
Thank you The Matrix I will try that :9Originally Posted by TheMatrixx
I have just right a little quistion, In The meen time I tryde wtih another movie (Hellboy) I worked fine In DVD maestro But When I try to updat the ifo file I get an error "VTS_08_1.srm is not correctly sized on sector boundary. ABORTING" Can yuo please tell what that meensBest Regards
Flarup -
Hello Matrixx,
I can't reach your guide to add subtitles.
(www.rodvd.tk)
Is your website down?? -
can anyone post a link for ReJig 0.5d, cant find it anywhere.
or contact me at zimcikf@seznam.cz or icq #66986178..
tnx -
That seems a lot of work, so here are my alternatives.
I prefer to just play the dvd with the subs on, on the source dvd player, then record on a dvd on a dvd recorder, recording to a dvd. The result? Open subs perfectly timed on a dvd. Amount of time, about a minute, not including recording time.
For a dvd that has no subs, but does have Closed Captions. Play on the source dvd player & run the signal through a Telecaption II using the video caption out on the back, record on a dvd recorder. The result? A dvd with open captions that doesn't require a captioned tv to see. Amount of time, about a minute, not including recording time. -
heyThe Matrixx I couldn't find out a way to upload my screenshot, but I can Tell you so much, that It dosn't help the length of the movie and audio is still different, I have the same problem with the movie "the Perfect Scrore" but when I demux The movie in VobEdit the lengt of movie and audio is the same, (this is not the result with the Starsky And Hutch Withch I start to taalk aabout), but if use the m2v file from vobedit I can't insert the chaapterfile from dvddecrypter so I still ahve some problems
Best Regards
Flarup -
Great job. But DVDMaestro can't (or I cannot) make multiple PGC
Is it possible to make multi-PGC DVD with DVDMaestro?
DVD-Lab Pro works fine with this, so I did copy "The Matrix" which is multi-PGC, though I got problems with menu (it doesn't work 100% - but 70-90%
). But the problem with DVDLab is that you can add only 2 subtitles to a movie. Have you any clues?
Snigel. -
Hi there.
I must say it´s a great guide. Done 4 movies within just a few days, and everything works great. DVDMeastro is not new for me so....
But; I do have one question:
Is there any way to change the text in the menu? I mean, when I have changed the subtitle from one language to another, it would be great to be able to change the text.
Pls, if you know....
/AnY -
Hi Anyone_xx, yes it is posible...but I don't know how. Sorry. Mabey I will found how to do that someday.
Hello eveyone:
Is there any way to use the last guide with shrunk movies.
Hi, jlspiderman and welcome to the forum. If you mean shrunk movies by DVD-5 or 4.7 Gb DVD movies...the answer is YES.
Why do you ask ? Do you have a problem ?Follow the white rabbit -
Flarup please make a screenshot of the error and post it here or send it in my private messages box !
Hello
TheMatrixx
I have tried your new guide and it works nice as hell...
The only problem is that the movie "crashes" whene it comes to the end of the movie. At the really end of the movie after the end credits it gets black and nothing happens. Is there anyway to fix so it jumps back to the menu?
Thx 4 a good translate of a very good guide
USiT -
Hi, USiT as I told you in your email...please put subtitle on another movie....2-3 movies...and see if are all the same at the end. If it's only this one....well...it happens some time. But if all are gonna crash at the end and not come back to the menu as supposed, I guess you are doing something wrong. Check very carefully all the options at IfoUpdate as in the guide picture.
Good luck.Follow the white rabbit -
Text in the warning Box "Chapter point position is invalid since it would violate the minimum allowable chapter length (0xc10c000b)"
Can any one please help me to explain this
Best Regards
Flarup -
And What about this
can any one please explain what that means
Text I this Warning Box "Asset overlapping detected.This can cause unexpected behavior. Choose undo to go bavk to the preious Or choose "list all subtitles" / the offending subtitles will be highlighted in red) and adjust the asset as requied"Best Regards
Flarup -
Flarup...the second warning ...the one with the Asset overlaping.....is from the subtitles...so enter the subtitles in SRT format in Subtitle Workshop and hit CTRL+I and fix the errors....till will be none...after you fix the errors save the subtitle as STL format and enter it in DVD Maestro again. This should take about half an hour....let me know is the warning still appears.
About the first warning....this a little hard....it's from the chapters...you must have a very short chapter...i have a movie like this...with a chapter at 1 minute....but you must have a chapter smaller than that....check the original movie and tell me if you have a chapter smaller than a minute or so.
Hi to all,
I'm having some problems with SubRip. I rip the subs from the original dvd and when I open the file in Subtitles Workshop most of the lines overlaping. I try to fix them but still some of them are overlap.
Why is this? I mean I rip the subs from the original dvd.
Someone help... -
It Worked Great :dOriginally Posted by TheMatrixx
Now I Will Take On a 3 week's vacation to Balaton Füred in Hungary
See You Later
Best Regards
Flarup -
Hello TheMatrixx,
First of all, I want to say, THANK YOU. Thank you for being so knowledgeable -- and so willing to share. While the various guides you have out there did not apply to my situation completely in a step-by-step fashion, I have had gratifying -- and repeatable success them.
I write to you now thinking that maybe sharing MY success might be worthwhile to someone reading the forum.
MY SITUATION:
I have recently authored a DVD of my old Super8 Film School projects from 20 years ago (anyone interested in the transfer equipment should wirte to me; I don't want to turn this forum into an advertisement for modified projectors). I've been having a great time editing my DV and authoring disks.
Then it suddenly hit me that I could share my films with my in-laws in Mexico. The thing is, most of them speak only Spanish, and I'm sorry to say I speak (and made films in the past) only in English. The solution? Add subtitles to my DVD! Unfortunately, only the NEXT version of my editing and authoring packages support subtitlles.
Well, I can identify with Evita here. I found that I HAD to use both guides because 1) I'm currently out-of-work and can't afford DVD Maestro to remux and 2) the guide that instructs on how to use the much cheaper Rejig doesn't mention using IFOUpdate.Originally Posted by TheMatrixx
After digging into the guides, I was stumped. I was having problems getting the IFOs configured well enough to turn on the subpicture attribute, mostly because the DVD of my old projects never had subtitles to begin with.
After running Rejig to remux all the original desired streams plus my new subtitles, dropping the VOBs back into the original DVD folder with the original IFOs seemed to keep killing my subpicture attributes on all my title sets. This is where IFOUpdate came in handy, it really seemed to look at the "Rejig authored" IFO and the original IFO and seemed to synthesize a useable NEW IFO -- except for the VIDEO_TS.IFO.
I wasn't sure if I should try using IFOUpdate to generate a new VIDEO_TS.IFO, or something else. The fact is, IFOUpdate was erroring out on me when I tried using it to synthesize a new VIDEO_TS... Here's what I ended up doing. I used IFOUpdate to correct the VTS Sectors on the original VIDEO_TS.IFO. Then I went in manually and turned on the subprciture attributes in each VTS entry in the original VIDEO_TS.IFO. I opened up the original VIDEO_TS.IFO file in IFOEdit, clicked on the VMC_VTS_ATRT, then went to the lower pane of the IFOEdit GUI and set VTSTT_VOBs from zero to one.
Tutorials: The Complete Guide to Macintosh Video Conversion
By galactica in forum MacReplies: 40Last Post: 9th Jan 2019, 19:25 -
Add Subtitles to DVD on Mac? guide? help
By spatafore in forum MacReplies: 0Last Post: 17th Mar 2012, 21:06 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 07:29 -
Subtitles not complete
By Antares in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th May 2011, 11:26 -
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 04:55
