Hi, I solve my problem using a new version of IfoEdit v0.971, which donīt have ntsc bug. Now I will watch my movie.
Results 331 to 360 of 654
Hello,
I'm having a bit of trouble re-authoring my Arizona Dream dvd with all the subtitles I want included. The original disk has a single subtitle stream that is forced and can't be deselected. When re-authoring with DVDlab pro the resulting dvd works fine but when replacing original dvd's vob files and updating ifo only the first subtitle stream that I've inserted works, the same way as the original did, forced. I'd like to be able to also select the other 2 subtitle streams i've inserted with dvdlab.
I'll also include the final dvd's ifos after ifoupdate, . Perhaps someone could inform me how to edit the ifos (or ifo) so that I'll be able to select any subtitle stream I'd like. If that is possible that is.
vts02 is the movie. 01 is the menu.
ifos.zip
thanks in advance
Solved my problem. -
hi dear
y did i get this massege after following your guide?[/img]WHO NEEDS A HEART WHEN A HEART CAN BE BROKEN -
I want to add new subtitles to a DVD keeping the original ones. I'm following this guide strictly but i always end up with a final DVD without the original subs and only with the new ones. I have three small doubts about this guide:
1) in DVD Decrypter (IFO mode) shall i demux the subtitles as well? (i tried both ways but the final result is the same anyway...)
2) what subtitles should be added at DVDlab? only the new ones right?
3) if i want to keep the original subs, do i must rip them before with SubRip?
I would really appreciate some help here.
This guide is really awesome
ok i have a problem. when i have a dvd with DTS or 5.1 surround then aftre demuxing and adding subtitles, muxing and burning again. it changes to 2 channel stereo. i believe it happens when i first demuxing it.
45tripp REPLACE THIS IFOs WITH YOURS !!! IT WILL WORK AS YOU WANT ... I REMOVED THE PROHIBITED OPERATIONS !
Have fun !
http://divxpert.org/NEW_IFOs_FOR_45tripp.zipFollow the white rabbit -
liavm we don't use the old guide, this one is working with DVD-lab PRO, DVD Decrypter and Ifo Update.
Try it ! It's the best !
If you still want to use the old guide use the new IFO EDIT 0.917 instead of Rejig.Follow the white rabbit -
Great WORKING guide, I even got the original subtitle on the movie I ripped and even add a new one! Now the next step is to get how I can add my subtitle to the menu, looks like I have to search for a new guide
Thanx The Matrixx for this guide!!!
//Fir3Fox -
Hi everyone, i'm new here, hope matrix can help or any of u guys, look i do all what the guide say until dvdlabpro i add the sub and the vob results perfect with subs but the problem it's that the original ifo said that have 2 pgcs 1 of the whole movie and the 2nd one with only 15 seconds so theres the problem cause when i tried to open ifoupdate doesnt works cause sau that the original iso got 2 pgcs and the authored one got only 1, how can i do with this:S cause it's freaking me out and dont know what else to do please help!
Hi chudm, I don't see what's the problem
Select the PGC 1 [2:20:20] and demux it
i mange to make my own dvd with my sub but
the sub was on movie himselef and not on the black space
how i can do it that the sub will be on the black space? -
Dear TheMatrixx, I just tried your guide for the very first time, and it works perfect!! I encountered some strange things though: with DVD Decrypter a .M2V file is made, but the AC3 files are not. In DVD Lab Pro I have to import a .VOB file, and then the AC3 files are generated. Besides that this works wonderful!!!
Thx.I know nothing -
Hi Amsterveer, please select in the Stream Processing window the AUDIO stream you want and check DEMUX option a little down! That will make you a AC3 file
Dear TheMatrixx, I did select the AUDIO stream! Actually there are 2 streams (2 languages), and I selected them both. I tried also single language DVD's, but I always end up with only a .M2V file, and a .VOB file that is demuxed within DVD Lab Pro!. Only after that (takes quiet some time) I have the .AC3 files available.
Thx anyway.I know nothing -
Hi i have problem how to do with structure like this it stagtae dvd with 5 title so if in 1 vob its 1 title and part from nother title so if i do last thing with ifo and i click on dvd play second title its play not from beginig plz help thnx m
Hi, a bit frustrating, but I only succeed when I mount an image (e.g. Iso) with Daemon, and decrypt it from the virtual drive.Originally Posted by TomghI know nothing
So which program would be best to make an iso.
I download'd WinISO but it didn't work, gave an error at 90 % :S
Or does someone know a program with which you can create a virtual dvd-rom drive of a folder? -
You can create an ISO or NRG or IMG file with I think any burning program. I use Nero. Just choose "DVD video", put everything that belongs there in the VIDEO_TS folder. Now select "Image recorder" as your burner, and then "burn" the DVD. This will create an .NRG file. Now you need a virtual DVD drive where you can mount this image (NRG or ISO) file. I use Daemon, which works perfect for me. You can download this from here: http://www.daemon-tools.cc/dtcc/portal/portal.phpOriginally Posted by TomghI know nothing
What if I have some TV episodes with subitles that I have turned to DVD format? How am I going to add the subs to the DVD with DVD Lab Pro?
Hi, I tried this guide out and was on its way to working perfectly until I came to compile the DVD. While in the Muxing process it stops in one place and doesn't move, I have tried 3 times to leave it thinking it would take a while but I left it on overnight and was still on the same place. No error messages or anything came up.
I'm compiling a NTSC DVD if that is any help. -
Tomgh make your ISO files with DVD SHRINK !
BlackAdder2TheRescue follow my new Episode DVD Subtitles guide from here -> http://www.dvdromania.org/content/category/1/76/56/
Deadite02 are you using NTFS harddrive ? Windows XP ? And please check you have a least 5 GB free space for the TEMP folder .. VERY VERY IMPORTANT !!Follow the white rabbit
Tutorials: The Complete Guide to Macintosh Video Conversion
By galactica in forum MacReplies: 40Last Post: 9th Jan 2019, 19:25 -
Add Subtitles to DVD on Mac? guide? help
By spatafore in forum MacReplies: 0Last Post: 17th Mar 2012, 21:06 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 07:29 -
Subtitles not complete
By Antares in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th May 2011, 11:26 -
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 04:55
[/img]
