Results 1 to 17 of 17
  1. hello, i need a little help here i was trying 2 make a mpg file 2 vcd in nero express, but it tells me this:
    any help would be great! tnxz
    ---PC mAnIaC----
  2. hehe... had a prob inserting the pic, but the problem says like this:
    The file "(movie).mpg" is invalid - need MPEG-1
    wich was encoded for Video-Cd:
    Audio: 44.1 kHz stereo;224kbit's
    video: 352 x 240 / 29.97 Hz or 352 x 240 / 23.976 Hz 352 x 288 / 25 Hz
    The following problems were found:
    -Stream encoding wich is invalid for a [Super] Video-Cd
    -No video
    -No audio
    pls a little help right here
    ---PC mAnIaC----
    Dec 2002
    My Swamp
    if you want a pic in browse for your pic with the browsebutton below where you write you post , the full adress of the pic goes in there.
    But in your post just put - in your case -
    [img ] Just marriedprob.bmp [ /img] (without the spaces}
  4. but do u know how 2 fix my prob
    ---PC mAnIaC----
    Dec 2002
    My Swamp
    Ive got that to say what I wanted now.
    Re your problem - What are the specs of the file you are using?
  6. [/img]
    ---PC mAnIaC----
  7. [/img]
    ---PC mAnIaC----
  8. Member teegee420's Avatar
    Dec 2003
    Southern California
    Just so you know PaTcHeR, your image can't be any larger than 50kb when uploading. You might want to experiment in the test forum.
  9. gspot just can say this:
    Size: 194 MB (or 198,884 KB or 203,657,865 bytes)
    mpeg format
    Video Source Type: MPEG1Payload
    Video path: (S) --> MPEG-I Stream Splitter --> MPEG Video Decoder --> (R)
    and something else : i converted it from boilsoft avi to vcd/dvd/svcd
    ---PC mAnIaC----
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    It would be helpful to know more specs such as resolution, frame rate and bitrate. You can get this info by opening up the mpeg with Virtualdub MPEG2 and going to File>File Information. Are you able to play the mpeg without any problems? I have a feeling your problem was caused by the Boilsoft program. They're not exactly known for their mpeg encoding prowess. You're better off using TMPGEnc.
  11. frame size,fps(us per frame) 352x240, 29 970fps(33367 us)
    Average bitrate 561 fps(69kb/s
    # of frames(time) 87064 (48:25)
    ---PC mAnIaC----
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    Looks like the bitrate is the problem. In order to be VCD compliant it must be 1150kbps. Try encoding the avi with TMPGEnc using the VCD template.
  13. ok, tnxz 4 all guys
    ---PC mAnIaC----
  14. just one more thing ... TMPGEnc is too slow .... it isnt as fast as boilsoft ... do u recomend me somethin 2 make it faster???
    ---PC mAnIaC----
  15. Member teegee420's Avatar
    Dec 2003
    Southern California
    Boilsoft also produced a shit file now didn't it?. :P Mainconcept MPEG Encoder is another good encoder and it's faster than TMPGEnc.
  16. and do u know if cucusoft is a good converter??
    ---PC mAnIaC----
  17. Member teegee420's Avatar
    Dec 2003
    Southern California
    It's not because Cucusoft is another one of those encoders that doesn't allow you reasonable control of the encoding parameters. Those are just cheap shortcuts that sacrifice quality for ease of use. The choice is yours.
