Fixes from beta 2
- Language combos shows more items than there are languages
- Some pulldown videos don't create chapters
- transitions have swapped blue and red color
- SetHL-button 0 not allowed
- Multiplexer, playback of pulldown files
- chapters are wrong on pulldown files
- audio on complex menu will not compile (but compiles on simple menus)
- more than 1 audio title will crash compiler.
- highliting trouble on some pal players
- DTS not all bitrates works (example SurCode 768kbps)
Additions, changes
- Play list is now renamed VTS Play list and doesn't allow bridge anymore (may be later removed for redundancy)
- Added Play list that can address any movie from any VTS without need for bridge
- Zoom out in Connections
- VTS Import is back, now you can import up to 3 external VTS's
- Added Non-Drop Frame and Drop Frame in subtitles dlg to "fix" the sync problem
- Sort assets by name or by type
- Add/Remove object to/from component
Figured I would give back to a site I have tken much wisdom from
Thanks for the heads up, downloading now.
http://www.mediachance.com/dvdlab/historypro.html
I hope it fixes the motion menu/links bug I'm having. And Thanks to Oscar. -
ah crap the stupid compile error bug is back like it was in beta1. Back to Scenarist for me.
Hi all,
With Beta 3, I like the fact that we can now use a Subtitle stream, the only thing I need to know is what format should this be in?
Also can we enable them automatically?
Many Thanks,
Paul Ryder -
DVD-Lab supports sub and srt as an import format. To get the subs to be on by default see:
http://www.mmbforums.com/modules.php?name=Forums&file=viewtopic&p=28719
http://www.mmbforums.com/modules.php?name=Forums&file=viewtopic&t=5008&highlight=subtitle
NOTE: their forums are down ATM. -
Thanks for the reply Dude...
I tried to import a .srt file and it didn't show up?
This might be a stupid question, but where in DVD-Lad should the .srt file be imported?
Many Thanks,
Paul Ryder
**** UPDATE ****
Oops, should have read the other forum before posting here...
The instructions are on there... Thanks again for the reply.
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 04:42 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 01:39 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53 -
Q, for those who use DVD Lab Pro...
By GangstaRap in forum Authoring (DVD)Replies: 3Last Post: 1st Nov 2007, 06:15
