After searching through the forums, I was unable to find an answer to this problem. I have found that every now and then my Sony DRU-510A cannot read a DVD (particularly ones from the early to mid 1990's). Anyway, since the Sony wouldn't read them, I used my XBOX which I have networked to my computer to read the DVDs and FTP the files to my computer.
So now I have several DVD movies stored on my hard drive (with the files exactly as they would appear on the DVD). The problem is that these files are still encrypted just as they would be on the DVD. Is there software that I can use on these files to remove the encryption? DVD Decrypter will not work for this, I don't think. If I can just do that, I can cut and resize the files to fit on a DVD-R. Any info is greatly appreciated. Thanks!
DVD Shrink exactly resolves your problem. Removes encyption, shrinks the files in DVD5 and if you have Nero installed writes them to DVD.
If for one reason or another DVDShrink won't do it. You could download Deamon tools (sp?). Mount the folder as a drive and run DVDDecrypter that way. That should work. But I think DVDShrink will do the job for you.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
Having trouble burning from hard drive to DVD
By becassier in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2008, 12:33 -
burning to my hard drive
By hawks770 in forum Newbie / General discussionsReplies: 2Last Post: 10th Aug 2008, 00:25 -
DVD Burning And Hard Drive Backing up..
By Mastablastacious in forum ComputerReplies: 15Last Post: 19th Jan 2008, 02:30 -
Trouble burning dvd from hard drive
By illyad in forum Authoring (DVD)Replies: 3Last Post: 10th Dec 2007, 11:20
