Hi, nero has me over a barrel (I think) when it comes to dvdr writing software, as in dump aload of files to a DVDR and pressing burn nothing elese will do that right?
Does anyone elese have the problem of once its finsihed buring that it crashes and freezes the system up? it also happens if your running it and instert a DVDR into the DVD Burner tray...
Im I alone here?
DVD region settings are a joke, I can't believe how stupid people are falling for it
don't have that problem, and I have been using nero for about a year and a half. I have yet to have a problem.
I've been using nero since Nero 4 with no problems of any sort. If you would describe it every detail what you are doing so we can maybe catch what might be the problem. Have you tried to burn with another program? Have ever been able to burn to DVD? Please give more info. We do want to help.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Record now maxOriginally Posted by Jumbo_Holden
Although Nero should do it no problems also, what version you running, have you tried upgrading to the latest version. -
Anytime ANY program crashes your computer, you have a conflict.
If Nero is crashing, something else does not like co-existing with it. Or, Nere does not like the other program.
Page file, whatever, 2 programs that are trying to access the same block of memory.
Any wierd shit you have installed on there? Try uinstalling the other stuff, try running Nero, crash, that was not the one, do it again
Or, try installing Nero early, allow it to set its territory. all other programs keep out .
Cheers,
George -
I burn with DVD Decrypter. Best way to burn IMHO.
Please note that DVD Decrypter can only burn from an ISO IMAGE file.
To get that you need ImgTools (the classic version).
That combination is pretty much foolproof when it comes to burning DVD discs.
best alternative to nero
By marlo in forum AudioReplies: 12Last Post: 29th Aug 2010, 14:53 -
software alternative to nero to put a dvd on my HW
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 07:36 -
Free alternative to Nero
By ddongle in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2009, 14:19 -
alternative to nero
By m-man in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2009, 11:57 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 11:19
