I was wondering if anybody knows if you can have Tivo without using a phoneline.(using my cable internet instead) It would be a long distance phone call everytime it needed to download the program lineup. I really want the service but I don't have a phone jack anywhere close my tv.
Thanks in advance for any suggestions.
Results 1 to 10 of 10
Yeah it actually worked. It recongized that it was hooked to a wired network and set itself up and worked. It was to easy.
GuestGuest
If you pay for the home media option,you can save recordings to your pc and burn them. I havent done that due to tivo video quality
GuestGuest
Just the image quality on my tv.Havent tried to burn it. Cable signal is ok. I get great hd reception.I know that tivo wont record hd. I am just less than impressed with the quality. I keep it for convenience.
perhaps i have the wrong end of the sitck...
I thought tivo captured your analog cable and encoded to MPEG for you to watch later? so if your cable reception is good your Tivo picture should be good, unless it has a crap encoder. or does your tivo work with digital cable, just recording the digital stream? -
GuestGuest
I believe the first is correct.I've read the quality issue as a frequent complaint in tivo forums so I don't think it is bad hardware.
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 14:03 -
Surge Protectors - specs for coax / phone line
By natalia25 in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2011, 17:45 -
i bought 3 movies on line but they don't download they play from on-line
By N8DOGB4000 in forum Video Streaming DownloadingReplies: 6Last Post: 10th May 2008, 16:20 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29 -
Internet and Phone Line Keep Going Off
By kerrex_2006 in forum ComputerReplies: 9Last Post: 7th Jun 2007, 20:38
