Hi everyone! How do i convert a divx to dvd using dvd2svcd and canopus pro coder?? i never had any problem doing it with dvd2svcd and tmpgenc but with canopus it's diferent, after the audio conversion VPAFI will open and i dont know what to do there. With dvd2svcd and tmpgenc you just have to open the avi you wanna convert and let it run for 3-4 hours and you have your mpeg2 but with dvd2svcd and canopus it will open vpafi right after audio conversion. And i dont know what to do there. Please some help, Thanks in advance!
Closed Thread
People i really need your help. I'm sure that most of you use or have used DVD2SVCD along with an encoder like CCE, Tmpgenc or Canopus Pro Coder and what i'm asking here must be quite simple but because for it's the first time i use DVD2SVCD together with Canopus i dont know what to do with the other aplication called VPAFI. When encoding with dvd2svcd and canopus right after the audio conversion dvd2svcd opens VPAFI (This only happens when using it together with Canopus) and i dont know what to do here. Do i have to open the avi again in VPAFI??? Please i really need some hints. Thanks in advance!
Get a pop up asking if I want to use ffdshow in Pro Coder ( what is it ? )
By beammeup in forum Video ConversionReplies: 1Last Post: 23rd Feb 2012, 02:37 -
Problem capturing with canopus mpeg pro emr...
By dhugg in forum Capturing and VCRReplies: 4Last Post: 5th Jun 2010, 14:43 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 19:29 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 19:18 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 04:15
