hi everybody,
since about 2 weeks, I flashed my UJ-816 to XXJ3 regionfree firmware,
with great success.
ALL PERFORMS FANTASTIC.
how is it about you.....???
cheers
sascha
Results 1 to 9 of 9
want to enlighten us how you did this. Dont have this drive myself, but if others are interested they will want to know how you did it.
The firmware and readme file are located here:
http://superdrive.cynikal.net/
It's located towards the bottom of the page. That's the only solution for ripping and playing DVDs from other regions at this point.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
hi WW,
what's about the best ripper in the world, MACTHERIPPER 2.0....?!
will it be out soon ?!!!
cheers
sascha -
It's in beta testing now. It should be released to the public within a week or two.
Hi! I'm not any computer expert and I'm afraid of doing any harm to my computer: I write this intro because I have this "region free" problem with my new Powerbook, and I was told to download (at my own risk, of course) this XXJ3 firmware. The problem is that investigating a litlle on the net, I realize that if anything goes wrong installing this "firmware", I may damage the machine and loose the Apple warranty.
I found that you have succesfully instaled the XXJ3, and now you can watch all DVD regions. What powerbook do you have? I own the 15' POWERBOOK ALUMINIUM SUPERDRIVE. Do you think it would work there??
Thanks!
hi lucchio,
no panic, it will work 100%...
my pb is 17" 1.33 with this drive:
Hersteller: MATSHITA
Modell: MATSHITA DVD-R UJ-816
Version: XXJ3
Seriennummer:
Laufwerks-Typ: CD-RW/DVD-RW
Medium brennen: Unterstützt/Geliefert von Apple
Wechselmedien: Ja
Absteckbares Laufwerk: Nein
Protokoll: ATAPI
Einheiten-Nummer: 0
Socket-Typ: Intern
read all carefully...
you need also region X from XVI: http://xvi.rpc1.org/
cheers
sascha -
Hi Sascha! That was a quick answer! Thanks!
I already have the REGION X software: it was when I installed REGION X when I realized that I needed to change the firmware.
I'll try it and then I tell you...
Thanks again!!!
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46 -
firmware page
By MEL15 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd May 2008, 07:43 -
DVD Firmware
By abercrombiedude0409 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2007, 14:27 -
Need DVD-RW firmware
By Strutinan in forum DVD & Blu-ray WritersReplies: 5Last Post: 13th Jun 2007, 07:19
