I searched the guides, and I searched the forums and I couldn't find the answer to my question.
I want to be able to convert a MOV movie to MPG so I can author and burn to DVD.
According to my search results, it can be done in TMPGEnc, but whenever I attempt to load it in this program, I get the "This file format is unsupported". I am running a PC with WinXP Pro (and not a Mac).
Any thoughts??
Thanks in advance!
Results 1 to 12 of 12
Maybe use one of the tools to convert it to AVI first, then open in an editor and save as MPEG.
Well I downloaded this plugin, and put it in all the TMPG directories (just to be sure), but still nothing. Still get the "unsupported" error. Am I missing a step?
I also got this error even with the plugin, although i dont know whether setting priority would change anything, if you have quicktime pro, then you can export to uncompressed avi, providing you have enough room on your hard drive.
If you can open the file in Virtual Dub Mod then you can framesrve it through TMPGEnc.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Originally Posted by tweedledee
why not use quicktime's mpeg export
tmpgenc and the MOV plugin and the K-lite codec pack or Quicktime so that the codec is there for MOVs and it seems to be able to convert to Mpeg under those conditions.
Second option go to apple's website and buy Quicktime Pro, it has an export function. All of the above have worked and are working for me.
Good Luck
mpg streamclip to convert .vob to .mov
By shard in forum Video ConversionReplies: 2Last Post: 10th Apr 2010, 22:54 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 15:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 11:30 -
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 09:51
