THANKS SO MUCH Daamon !!!Originally Posted by daamon
I'll give a try !
Zetti
Results 31 to 39 of 39
Well, sorry Jeff, but I don't understand......Originally Posted by hiptune
Do you mean that it's necessary to create the actual DV file to input at Procoder ?
Isn't there a plug-in to Premiere Pro that should frameserve to Procoder ?
This would be an undesirable extra step....
Zetti -
Sorry about that Zetti, a typo on my part.Originally Posted by Zetti
Procoder needs no extra step of framserving, that was my point. The avi's that come out of Premiere Pro need not be frameserved to Procoder, which is not the case with Tmpgenc.
For tmpgenc you need to frame serve avi, or it will not accept it.
lots of talk here on the subject, but nobody has explained why this is. I just simply use Procoder for my avis that are from Adobe, and use tmpgenc for other edited avi's when I use Studio 8 which has some amazing quality editing features, and weak encoding. And I don't read too many comments that Mainconcept (adobe) is that great either. So I stick to Procoder and tmpgenc for encoding. And I get professional results with the right settings.
Jeff -
No problem. I had it recommended to me only recently and found it really easy to use.Originally Posted by Zetti
Thanks. I'll check it out.Originally Posted by Josef K
No, only mods or Baldrick can do that - the original post was in the "DVD Authoring" forum (now moved). Good spot - If you mention it in the "Please report problem posts / threads / members here!" sticky in the "Feedback" forum, the mods will correct it. You're taken there if you click "Report this post".Originally Posted by hiptune
Hold on - you gave sparse information, originally only asking "But why does ProCoder handle Adobe Premiere avi's but Tmpgenc does not? Is this a codec issue, or some other issue(s)". Quite a sweeping general question, and against a lot of people's experiences (especially as you don't quote version numbers to clarify Premiere 6.0 / 6.5 / Pro).Let's move on now unless you have some real solutions to add rather than asking what the problems are, what the errors given are, etc. and then offering up no answers other than to frameserve.
For people to be able to help you, you have to give them something to go on. If you don't, and if they want to help, they're gonna have to ask questions. I don't think mine were unreasonable given the lack of info you provided. Granted, in the end I couldn't help, but has it not occurred to you that, by dragging info out of you, someone else might have been able to help? If nothing else, the topic goes back to the top of the pile on the home page, and someone might pick it up because of it.
Before you start criticising others, I suggest you look at the causes of your dissatisfaction and consider that you might be one of them. Communication is a 2-way exercise, so is poor communication. If you're a poor communicator, you'll get poor responses.
I suggest you re-read the thread. At no time have I said that frameserving is the answer. IMO, I believe that frameserving has benefits that apply to me and to a lot of thers, but it's not the solution to your problem (the one you vaguely stated, not the one that's transpired). Frameserving is a matter of personal preference. It's not a "must do" step in the process.Originally Posted by hiptune
Another wonderful general sweeping statement. If you're gonna make these, please support with versions of source program, what type of AVI (DV, Microsoft DV, DIvx, Xvid?), versions of TMPGEnc etc. As it stands, you're comment is neither right nor wrong - but definitely misleading. By trying to help Zetti here, you're just giving him incomplete info that will mislead.Originally Posted by hiptune
Are you surprised? Have you provided details of your TMPGEnc setup? Have you used AVICodec (as suggested) to give details of your AVI / codecs? As I've said before, I save to DV AVI from Premiere 6.0 and TMPGEnc accepts that just fine - and it does for a lot of other people too.Originally Posted by hiptune
So, I'm sorry to say, but it might be your setup and attitude that's not correct. Now, I would ask some more questions to get some more info so that I, or others, can try to help - but as you don't think that's a worthy approach I shan't.
All that said, it seems you have a process you're happy with - I'm happy for you.
@ houseng - My apologies for the above in your thread. I felt compelled to defend myself having tried to help someone and had resentment and a lame attempt at sarcasm in return.
Where do you stand with your problem?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
It occurred to me, having re-read the thread, that the above still appears to remain unanswered for you. Rather than having you trawl through the thread, I'll summarise my thoughts:Originally Posted by houseng
1. I used to save as DV AVI in Premiere 6.0 and TMPGEnc Plus v2.52 took this perfectly OK.
2. I then looked into frameserving (as, for me, there were benefits in disk space and time saved). I eventually went for the PluginPac FrameServer.
Once installed, when exporting the timeline as a movie, choose pluginpac rather than "DV AVI" etc. Then, use the file saved in Premiere as the file for TMPGEnc etc.
Frameserving also bypasses the need to save as a particular AVI format. That said, I'm not sure if it bypasses the use of a codec - I suspect it will, but don't know for sure.
Can you explain what you mean by "making you dizzy"? I've seen this type of term before and people were referring to horizontal lines when there's left or right movement - looks like a comb effect? This is interlacing effects.
When encoding DV AVI with TMPGEnc, you need to set it to "Bottom field first (field B)" on the "Advanced" tab in the settings.
That said, interlacing effects seen on a monitor may not appear in the finished article when viewed on a TV - this is due to the fact that monitors display the picture using what's called "progressive scan", whereas TVs display using "interlaced scan".
So, I'd suggest to go ahed and author to a DVD rewriteable to check it out on your TV. That way, you can erase if it's still making you dizzy.
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Jeff, please, what EXACTLY version of Procoder do you use ?Originally Posted by hiptune
Thanks,
Zetti -
@ hiptune - I've just been reading another thread, and it struck me that this might be what you're experiencing. Of course, it may not - but I'd thought I'd post it in case it's of any use...
https://www.videohelp.com/forum/viewtopic.php?t=220182
A quote from the above thread: "...the conversion just shows a black screen, like no video is being encoded or something..."There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 18:21 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
How does Adobe Premiere 2 rate
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 00:08
