Hello.. can anyone help me? i recorded some movies with my camcorder. then i want to edit them in my computer. but since TMPGenc does'nt allow advance editing, so i used adobe premiere to edit them. but after i edit, i wanna convert them to MPEG2 using TMPGenc, so what output file should i output from adobe premiere?
i tried to output my edited videos to AVI full frames (no compression), but the mpeg2 encoded from the uncompressed AVI makes me dizzy.
can anyone give tips?
Results 1 to 30 of 39
Yes, go to www.videotools.net, and see about the video server plugin. It lets you send edited Premiere files directly to TMPGEnc with saving them first.
Hello. -
YOU COULD ALSO USE (PLUGIN PAC FRAME SERER) AND IT IS NOT A BETA
Originally Posted by stacknerThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
But why does ProCoder handle Adobe Premiere avi's but Tmpgenc does not?
Is this a codec issue, or some other issue(s).
No Really?
Jeff -
Originally Posted by hiptuneThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by daamon
Jeff -
hahahaha. well many of us frameserve from premiere to tmpgenc becouse we like tmpgenc's encoder a hell of a lot better. i find the end result with it to be a much better quality mpeg than with premiere's built in encoder. i also find that if i frameserve to tmpgenc not only to i get better quality but it also encodes in atleast half the time.
so now i ask why NOT frameserve? unless you can't lol -
Your original question is open to various interpretations. As the original poster was talking about frameserving, I opted for that interpretation of your question. If you want the correct answer, ask the right (precise) question. I'm not a mind-reader.
1. No disk space required: Frameserving from Premiere (or anything else) to TMPGEnc (or anything else) removes the need to save the project to file, useful if you're tight on disk space, because it passes each frame, as and when requested, via memory.
2. Time: You don't have to wait while the output is rendered and then saved to file (DV AVI in my case). Admittedly, it's not a great time-saving but, for longer footage, removes the need - why wait unneccessarily?
Some frameservers, like AviSynth, can also perform functions on the video as it serves it (resizing, filtering etc.) - very powerful and useful.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Jeff -
Having read the latest post, it seems you're asking why TMPGEnc over Canopus Procoder? Personal choice (based on reading alot here), budget etc. That was my influencing factors.
Carpe diem.
In all seriousness, it sounds like you enjoy the flexibility in frame serving for your needs. But I have large hard drives, and have other options for filtering and sizing, etc. Those are not advantages to me. And I need back ups of all my avi's for other encodes, and other cuts of the material.
I still would like to know if this is a codec issue? I think that is precise as it gets.
Jeff -
When you save to AVI from Premiere Pro, what type of AVI do you choose? Use AVICodec to get info on the AVI file and post back. Also, when you say "TMPGEnc does not" - what error message are you getting / problem are you encountering?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I played around with Premiere Pro for a while. What I wanted to do was take files recorded off TV in MJPEG format, edit them and then convert to MPEG2. I gave up in the end because as soon as I edited the files the sound went out of sync and Adobe on their forums weren't able to offer much help. Now I just edit the files in Virtualdub and frameserver to Mainconcept.
But when I was using Premier I was able to
1. use the builting mpeg2 encoder in Premiere (supplied by Mainconcept)
2. Frameserver to Mainconcept
3. Frameserve to tmpgenc
BTW 1. was the fastest, followed by 2. and then 3.
the last two using the freeware framserve software that is available on the net
For Premiere 6.5 I think Adobe used a different mpeg2 encoder so frameserving was more useful -
Originally Posted by houseng
What you want to do is export the AVI's from Premiere as uncompressed. Then use TMPGEnc Plus to convert the AVI to MPEG-2 and to Demux the sound. Then use TMPGEnc DVD Author to make your DVD.
You are skipping the TMPGEnc Plus step. TMPGEnc DVD Author does not support AVI files. This process will work...I do it all the time.
Premiere's DV-AVI sucks, Microsoft's DV-AVI is just as bad, and Premiere's MPEG-2 encoder has some issues and I personally don't like the quality...I always have interlace issues with it. -
Is it a known fact that "it sucks", i.e. general consensus?
Does frameserving bypass the use of the codec?
Originally Posted by housengThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
But at any rate, you have not been able to help with my questions. You might try importing into tmpgenc with out frameserving, and see what happens. Then you might understand what all the fuss is about.
Thanks anyway,
Jef -
It might be because the Microsoft DV AVI is coming out as type 1 DV AVI, when TMPGEnc very much prefers type 2. I did read up on the differences but can't remember now. All that I needed to know is that I wanted type 2 DV AVI for TMPGEnc.
There is a tool called DV Type 1 to DV Type 2 Converter - name speaks for itself... There's also Canopus DV File Converter. I haven't used either...
P.S. It looks like your "Disable BBCode in this post" is ticked - that's why you're quotes look as they do. This is probably set in your profile and so will happen every time. Just untick it in your profile. You can even go back to existing posts, click "Edit" and re-submit without the box ticked.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Carpe diem.
Carpe diem.
Jeff -
Hi
Mmm... I've not come across that, and don't recall seeing it in the forums. The following is a quote from TMPGEnc common problems and tips
"If you have problem open DV AVI files
First install a DV Codec and be sure that you can play DV AVI with Media Player.
Then try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and reopen the video.
If that doesn't help you may need to convert the DV to Canopus reference DV (TMPGEnc do not support Microsoft DV AVI 1)."
I don't know if it'll help... Sorry.
@ houseng - How about you?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hi Zetti,
Install PluginPac FrameServer - I use it with Premiere 6.0, so should be OK with Pro.
When exporting timeline as a movie, choose pluginpac rather than "DV AVI" etc. Then, use the file saved in Premiere as the file for TMPGEnc etc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
With Procoder there is no need to frameserve, it works perfectly with it that extra step.
Jeff -
Daamon, have you changed the topic here with these posts?
Should be in encoding, not authoring. But whatever.
By the way, there is no error that comes up in tmpgenc, it simply gives you a balck screen with no video to encode.
But with Procoder, the file from Premiere Pro is fine, no need to frameserve.
Ok, you must have learned somehting here, even if you were not able to shine any light on the real issues.
Let's move on now unless you have some real solutions to add rather than asking what the problems are, what the errors given are, etc. and then offering up no answers other than to frameserve.
Jeff
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 03:14 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 17:21 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
How does Adobe Premiere 2 rate
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 23:08
