I have all the episodes of the anime Cowboy BeBop on retail DVD. i would like to back them p to as few DVD's as possible. I would like to know the preferred settings by other people out there when they convert anime. I have the Mainconcept Encoder and TMPGenc so I have some flexibility in my options. Thank You for your response.
Have a look at DVD Shrink. You may not have to re-encode at all.
Not necessarily. All you would need to do is rip all the VOB's to your hard drive and re-author with something like TMPGEnc DVD Author or DVD Lab.Originally Posted by EvergreenTerrace
I recall a method that may do what you are looking for, that basically involves ripping all the episodes you want to your system, create your custom menus as required, this will probably mean that result is to big for DVD, don't worry about that for the moment
At this point, you then run the completed result with the custom episodes and menus through DVDShrink, Nero Recode, whatever transocoder you have access to
This, in theory, should then squeeze all your work to fit onto a single DVD in one shot, you've already done all the hard work is creating the custom DVD, so just let the transcoder do all the rest and burn the final output, which should now be the perfect DVD size, onto a DVD blank -
Very true Teegee, I didn't come at it from that aspect. Ok but here is another added question. If you had to pick a lowest bitrate for anime onto DVD what bitrate would you go for? Thanks
2500-3000kbps using a resolution of 352x480/576(480 for NTSC/576 for PAL).
Anime conversion with out of sync subtitle (help needed please)
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 1st Mar 2010, 06:44 -
Complex Anime ripping question. Please read. TYVM! ^_^
By Dratheus in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2009, 01:52 -
Anime FPS/Interlaced question...
By alcOre in forum Newbie / General discussionsReplies: 6Last Post: 4th Apr 2009, 09:05 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31 -
Anime Backup Question Plz Help :)
By Azures in forum DVD RippingReplies: 2Last Post: 2nd Jun 2008, 15:37
