Ulead VideoStudio Pro 8 Trial won't work with my BT878 card (Universal WDMN drivers). When trying to get into capture mode, it says: "Unable to switch to Capture Mode. Check if your video capture driver is working properly. Can not preview." All other capture programs work nicely. Any help will be appreciated.
I was wondering if there was a resolution to this issue, as I am having the same problem w/ the full version of Ulead VideoStudio 8.
Any help would be appreciated. I am using the Conexant WDM Video Capture for Bt8xx based board drivers (5.3.8), on an ATI TV Wonder-VE card. -
Use another capture program before ulead, to activate the drivers. For example, open virtualvcr just to see picture. Then close it, and open ulead.
Sometimes this helps...
(Doesn't Ulead still use vfm drivers along side with wdm ones?)
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
Widescreen Output Using ATI Theater 650 Pro and Ulead VideoStudio X2
By waldodiodio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 11:00 -
VideoStudio Pro X2 OR Magix Edit Pro 15 Plus ?
By Dash1 in forum EditingReplies: 1Last Post: 25th Jun 2009, 20:26 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
m2t files won't work in Vegas Pro 8
By Patokid in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2009, 15:47
