Recently, a friend of mine purchased the Region 4 PAL version of Mulholland Drive, a film that I have not seen before. You can imagine his shock when he played the disc only to find that there were absolutely no Chapter Stops during the entire 141-minute length. Ever since, I have been trying to find a way to make a backup with Chapter Stops so he can navigate a little easier.
Which brings me to the meat of the matter. While there seem to be plenty of guides available for inserting Chapter Stops into camcorder footage to be burned to DVD, there is nothing explaining a procedure to rip the contents of a DVD-Video, insert Chapter Stops, and then burn it to DVD-R. I've been hitting my head on the wall with IFOedit all day, and quite frankly I am not inclined to use it again without a step-by-step guide.
I'm not sure if you want to keep the original menus, but some authoring softwares will let you take the ripped content and put in chapter points (TMPGEnc DVD Author comes to mind).
Also, unless chapter-less is standard for that version, maybe he can return the video in exchabge for a copy with chapters. -
Thanks, Supreme, I'll give both of those points a try. I suspect, however, that the Chapter-less format is standard for this territory, as the menu on the disc also has no mention of them anywhere (nor does the cover art).
What an idiot.
Oh well, just gives me another challenge to overcome.
I think I would do a movie only rip with DVD Decrypter the add chapters with TMPGenc DVD Author
I'm in the process of doing that now.
Here's to hoping it actually works.
Numpty's Guide Please
By Dan Dare in forum Media Center PC / MediaCentersReplies: 7Last Post: 10th Dec 2008, 02:55 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 21:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 23:34 -
How to use Linux? Guide
By mjack425 in forum ComputerReplies: 2Last Post: 24th May 2007, 23:55
