Anyone know what is the longest record time possible with this format?
Results 1 to 9 of 9
I don't have a bad attitude...
Life has a bad attitude! -
For most camcorders it's 90 minutes, but that's in LP mode which you may or may not want to use. LP mode compacts more info on the tape by putting the data closer together. This can cause compatiblity problems and can even make the tape unplayable in the future on the same machine that recorded it.
I am willing to be corrected but somebody who has one told me to obtain the quality required for DV video on 8mm tapes, the D8 cameras run the tape 2x regular spped. So from that you would extrapolate that the max time is 50% of whatever 8mm tape you're using
BTW they are a great device if you have a lot of Video8 or Hi8 tapes (as I do) and want to move into digital video while not obsoleting your catalogue. Plus I think some models do passthru so you can take a regular video signal from a VCR, pass it through and feed the output via firewire to your PC -
Plus, when I use A/D pass through with my Sony TRV840 D8 when transferring prerecorded VHS tape to my stand alone DVD recorder via FireWire, it disables Macrovision. -
Originally Posted by lchiu7
Originally Posted by MpegEncoder
I've read the same thing about Mini\DV LP mode, though I don't know how true it is.
I need to be able to record 2hrs at a time though. Guess I'm back to MiniDV, which can record 2hrs onto an 80 minute tape. I was hoping to take advantage of D8's lower tape prices.I don't have a bad attitude...
Sony has a Digital8 tape which holds 90 minutes at the higher SP quality. They're more expensive ($10 per tape or so), but quite handy when storage space is an issue. Last year I took 6 of these on an overseas trip--the equivalent recording time of 9 60-minute tapes. I've never tried recording LP (don't trust it), but I think these 90 minute tapes will hold 120 or 135 minutes at LP speed (I'm just remembering the packaging). I get mine at Best Buy.
Thanks civic, but I'll probably still go with miniDV, as miniDV 80min tape runs about the same price (or even a couple of buck lower), and I can get more of the camcorder features I wanted with miniDV as opposed to D8 (like a 3" LCD and headphone jack).
MiniDV is probably the best way to go...D8 is on its way out. Sony has gradually decreased the number of available models to almost nothing now; my 3-year old TRV525 has the larger LCD and headphone jack which you mention. The analog pass-through which someone mentioned earlier in the thread has been really helpful to me in capturing analog video to the computer.
Reading 8 mm and HI8 tapes in Digital8?
By tentate in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 28th Dec 2009, 10:58 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Sony Digital8 Camcorders
By k2skier in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2009, 13:10 -
Erasing Digital8 tapes
By skieffer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Jan 2009, 12:24 -
Using Canopus with Digital8 Camcorder...
By guber in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2008, 14:19
