Closed Thread
  1. Here is the dilly yo.
    Just downloaded some .bin and .cue files of a friends movie. He has a PC I have a MAC.
    When i try and drag these puppies into toast 6 to make a VCD it says
    "It is an unkown format and cannot be imported"
    What? they are bins? Aren't they? Can i convert them to another file format? Like MpG?
    Any workarounds would be very much appreciated. I have ffmpegx.
    I am really at a stale mate here.
    Thanks Dudes,
    -Nathan
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
  2. Anyone?
    Come on people no ideas or solutions? Anything would help!
    Point me to a post or SOMETHING!
    -Nathan
  3. dont be an *******. one thread is enough.
    https://www.videohelp.com/forum/viewtopic.php?t=219387
    https://www.videohelp.com/forum/viewtopic.php?t=219386
    vcdgear will convert'em for you
    http://www.vcdgear.com/download.html
    there is an OSX version
    you could also try using a pc emulator & the windows version to convert the bin/cue to mpeg.
  4. HA ha ha ha MAc user :P
    You need to mount the bin and cue in a disc emulator then you can manipulate the files therein anyway you like.
    Or something like ISOBUSTER or vcdeasy can extract the mpg files
    or Burn it using something that supports bin+cue files, they are just cd images..even use a cdrw to test (the mac can use Cdrw cant it?)
    The electronic components of the power part adopted a lot of Rubycons.
  5. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    eeeehhhh wrong.
    1. put the .bin's on your hd
    2. extract out the .mpeg files with VCDtoolx
    3. you will get mpeg files which you can then convert over to anything you want. Authoring them this way ensures you will be able to burn them properly.
    burning requires
    toast 6 in Copy mode, FireburnFX, or Missing Media Burner
    oh yea... as jeex pointed out. Once is enough
  6. Whoa, you guys strike with quick and deadly force. Sorry about the mass spamming.
    Anyhoo. I am still working on this problem. VcdToolsX does not exist anymore. If you could find me a link that works or another mpeg extraction tool you would suggest, I'll make you a milkshake.
    Pc emulator I'm a little bit against, but if there are no mac solutions well, it's bullit (as the movie) biting time
    thanks for the help kiddies!
    Cheers Nathan
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Please don't cross post.
    Please wait a few days befor bumping a topic.
    Please post in correct forum. The MAC forum!
