on dvd lab once ive done chapters and compile the disc then i try 2 burn it it says error disc not found and something eles i am useing a sony disc it says dvdr so if thats the problem then where is the guide 2 change dvd 2 dvdr (i have tryed this but video_ts has no files in it also i look in the folder and theres nothing there![]()
When compiling the dvd, look at the pie charts. Do you have enough room on the dvdr? Do you have enough room on the temp drive? Do you have enough room on the destination drive?
Does DVDLab support your burner? Is it selectable from the burning menu after compiling?Cheers, Jim
My DVDLab Guides -
I wouldn't try burning with DVD-Lab, it's a very rudimentary ASPI burner (in fact it crashes on my PC.) Even the author of DVD-Lab recommends you use the burner program that came with you DVD burner, or some other burner program like Nero etc.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 08:57 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
